strangeandbouncy
Dear all,
I used to use an ATC active crossover to split my mix into three bands, and often used the optical limiting on each band. This was years before TC finalyser, Focusrite, or Tubetech, - but I won't any credit for the concept. That was a suggestion of the marvelous Roger Quested. (to me ,anyway!) (We used to use the ATC when I first worked with him). I would say that the results were a bit crude, but then again, so were my mixes back in those days! I have often wanted to build a crossover enable me to split my signal into 2 or 3 different stereo compressors. I have details of active crossovers, but what I was wondering was would this work with a 12dB/octave x-over, or should I use 24dB/Octave? If 12dB/8ve is ok, could this be achieved passively with LC network? How would I go about calculating the values? I have tried to find some documentation on the web, but to no avail so far. I was also thinking of using transformers to recombine a 2-way split-signal.
- Or should I just buy that £68 Berhing@@@er, 2 way, active, stereo, 24dB/8ve, Linkwitz-Riley box?
Please, tell me that there is another way!
I am forever in your debt, guys! - Andy P
