Beesneez James serial 42?
OEM body style maybe 2009/2010?
Both sides of the capsule need a re-skinning.
It passes audio and used to work great but now it gives "wooooosh wooooooosh" seashell sounds when used.
The tube could use replacing, the noise floor is a little skittish at times which I suspect could be the tube.
Comes with the original hard case, PSU, 120VAC cable, shock mount, 7pin XLR cable.
Selling as-is $600 obo
