Tlm67/U87 to U67 mod
Hello Max,
Are you still making the TLM67 to U67 mods?  I've been holding onto my money waiting for you to come back to gearslutz.  Please tell me that a new batch is coming!
Max, is there a chance you could post pictures of the TLM67 capsule wiring?  I ordered one of your kits from a guy off eBay and service parts from Sennheiser to complete the mic, but I'm confused on the capsule to switch assembly wiring.  Thanks.  Jimi Ray
Got it finished.  IOAudio TLM67/U87 mod, Neumann headbasket and switch assembly, Neumann K870/K67 capsule, Neumann NOS U67 body tube and body cap screw.  The headbasket assembly was a bit tricky putting back together once the capsule was mounted (due to the plastic switch pins)...
I dropped way more money on this than I should have but I wanted it to look as authentic as possible.  These are the parts I purchased from Sennheiser (the NOS U67 body tube came from eBay seller "alphaville777", but the standard U87 body tube will work and I listed it below):
    - U87 capsule K870/K67  053225  $639.56
    - U87 housing tube 092465 shows as 205.09 Pounds Sterling on website but will be less when you call
    - TLM67/U87 headbasket 092454 $320.66
    - TLM67/U87 Switch Deck 060746 $424.08
    - U67/87 bottom screw cap - nickel 071070 $150.40
    - U67/U87 Shockmount (Peluso - eBay) $202.15
I think it would be cheaper to buy a TLM67 and just replace the body tube.  Not sure.
Contact Sennheiser at 860-434-9190 ext 1 a to order.
Thanks Jimi.  I ask because I already have a couple of k870 capsules on hand.
Maybe I'll sell the capsules and get the Tlm, but then I still need the body tubes.  Those anniversary versions are ugly.
Let me know if you decide to sell the K870's.  I could use one or two.
