BOB KATZ line level buffer
chrissugar
EU
Did you know about this?
http://www.digido.com/User/Assets/Active/PDF%20files/00478-buffer.pdf
I supose if you remove the feedback [R10,R11,C2] , the DC servo and the input circuit [R8,R9,C1] you have a great buffered opamp. Maybe it is doable in a 990 footprint.
chrissugar
I'd really like to see a greater 'base spread' across D1,D2,D3 and (inexplicably) D5. -As is is, it looks like there might be a bit of crossover distortion...?
Inserting a trim pot in there might allow the quiescent current through the output transistors to be trimmable to a greater degree... or at least a bit of series resistance...
Keith
