API 553 PCB
Hi Kevin, thank you for the photos.
Unfortunately the PCB of your module is the original API that has some little differences in the traces from the Datatronix PCB posted by Gary
Here is one of my Datatronix Modules with the DOA removed
so you can see the traces thru the PCB.
The markings for R13 and R14Make no sense to Jeff's Skitz.
These 2 Rs are un-need anyway so I just ignored them
Looking at what I did to make these guys work... note the 2 Jumpers.
This puts the PCB in sync with Jeff's Skitz (except R13 & R14)
Hope this helps! :)
This help a lot Gary !! :)
As I need to have a balanced input and unbalanced output, do you think it is possible to use this eq without the output transformer with a 10k:10k transformer for balancing the input?
Merry Christmas to all!
Fab
Fab
You can use your input trafo  and keep the output trafo but run it unbalanced.
GARY
Kevin, my question is if I can put on these module a 1:1 transformer intead of the original one that is 1:3
and what happens using a different ratio  :)
Happy Christmas
Gary,  when you say to run the output trafo unbalanced you intend joining the negative of transformer with the ground?
Thank you Gary
Do you know if there is a 2520 type opamp that can be used without transformer?
I am considering to use a couple of these modules in a portable channel strip
Gary, do you know if there is a 2520 type opamp that works with  +28/-28 Volt?
Happy new year to all!
Does anyone know what the dimensions of the board are?  Looks like it may be different than the standard 500 series spec dimensions I can find?  Thanks!
