Transformers! transformers! Vintage transformers for tube circuits and more!
I need an input for a Gates SA-134,  #AI-3006.    Spec sheet attached, not that you don't have it!  It's different than the AI-3009 you have listed.  Wonder if the 3009 might work, or if you have a 3006?
  • Gates trafo.pdf
Only difference is 600 instead of 50 ohm tap, both have 250 (note typo in catalog), and 10dB higher level handling in 3009.
is it available? thanks
Altec / Peerless 15095A NOS/NIB
New in box.  Used in 1567A, 1566, blah blah blah.
$80 plus shipping/insurance  on 1 lb.
Iain, what book or manual is this page? I am searching datasheet or info for a AO-3045 Gates Transformer!
Thanks alot antocipated,
opacheco
