Hi Group,
I continually run into a problem with accurately measuring Z-height (vertical tool position) on my machine. Need >0.05mm depth precision at all times for decent engraving.
The unit has too little Z clearance to use a standard toolsetter - all I have seen are 50mm or more.
So I was thinking: These small, inexpensive digital scales - made for kitchen or drug-retailing use.
They rely on something called a "load cell" to measure weight - but in fact, I think they actually measure mechanical displacement vs. some spring resistance.
Readout seems to be an accurate function of vertical mechanical displacement. And there are hacks out there to interface to Arduino - so it's relatively easy to generate a metric look-up-table from raw sensor data.
Do you see where I'm aiming?
Any problems here that you can see - before I invest too much energy into a proof-of-concept?
Jakob E.
Jakob E.
