S Steve Jones Well-known member Joined Jun 4, 2004 Messages 506 Location Sydney Feb 24, 2005 #1 wow, how many glue sticks did that take? you must have been tripping on the fumes. Great idea though...
gyraf Well-known member Staff member GDIY Supporter Moderator Joined Jun 4, 2004 Messages 11,883 Location Aarhus, Denmark Feb 24, 2005 #2 I have mine epoxy-filled from the manufacturer, but this is a nice trick for off-the-shelf types. Just don't run the toroid at max. current - if it gets hot, you'd risk melting it off it's holder.. :grin:
D Dan Kennedy Well-known member GDIY Supporter Joined Jun 5, 2004 Messages 294 Location Inver Grove, MN. Feb 24, 2005 #3 JB Weld, a high temp, high density two part epoxy available in hardware stores does this trick really well too. It drills and taps just fine once it's cured.
