critterkllr
I put the pot in place, but I’m just having a really difficult time following the calibration instructions.
If I’m using pro tools to send a sine, do I set it to -30db in the signal generator? If so, do I set it to Pk-Pk or RMS?
Or do I measure voltage using a DMM and adjust it to whatever hits the mark? Do I measure Pk-Pk or RMS?
Do I measure from the test point or +input to ground? Or between the + and - of the output?
I have pro tools, a DMM, and an oscope.
« Last Edit: May 08, 2020, 12:55:43 PM by critterkllr »
jsteiger
I put the pot in place, but I’m just having a really difficult time following the calibration instructions.  I’m the third person this has been passed along to that doesn’t get it.
I have pro tools, a DMM, and an oscope. How do I do this? Would Hairball Audios instructions work for this?
Someone posted DAW tips a while back on this thread.
Visit the CAPI store at http://www.capi-gear.com
CAPI is not affiliated with, endorsed by, or sponsored by API.
critterkllr
I can’t find any actual tips. Just lots of issues calibrating.
Okay, so I’m goin to be as detailed as I can be. I am using a psu with a db25 connector, and a DIYRE extender to lay the module out.
I’m sending a 1k sine wave from pro tools. I’m using an oscope to measure the +/- +4 input pins on the extender and am getting .024 VAC RMS.
Once verified, I take the extender and plug in the compressor.
When I look in Pro Tools, that monitoring signal is too low to make any sense of it. So I boosted the bypassed signal up to -3dbvu using the VU style meter. When I power on the unit, it jumps to around +.25dbvu.
Am I in the ballpark? Your instructions say I should have a massive jump from -30dBu way up to +7.75dBu. So am I way off?
critterkllr
Okay, I made some progress. The person that built it soldered a lead into TP9. It was bent down and touching something.
Now, when I switch from bypass I go from -49 to -11 in my DAW. If my math is correct, that should mean it’s calibrated to -19 dbfs and that should be the same as -30 to +7.75! Woohoo!
Got the fet into it’s conductive range and it’s down by 1db.
Meter is calibrated and she is good to go! Hard to believe I'm the third person to look at this and it took so long. Thanks, Jeff.
« Last Edit: May 08, 2020, 05:12:50 PM by critterkllr »
jsteiger
You can easily measure ACV at the output of your DAW signal generator) to verify the -30dBu level. Simply hook your DMM's red probe to XLR pin 2 and black probe to XLR pin 3. To test the response of your meter, 1kHz @ 0dBu = .775V (RMS). If your meter is not measuring .775V AC check it at 400Hz. Not all DMMs can accurately measure 1kHz.
For reference:
0dBu = .775V AC (RMS)
-30dBu = 24.5mV AC (RMS)
Here's a helpful calculator
http://www.sengpielaudio.com/calculator-db-volt.htm
GrantB
FC526 XFMR here, it "works" but has low signal levels throughout.  TP1 = 4.94mV with input -30dBu/24.49mV balanced.  Trace all the way back to the inputs, ~9.8 mV on both + and - input all the way back to the edge connector.  Same result with rack powered off.  Disconnect card and pins 8 and 10 of the extender return to 12.24 mV.
Power pins and PRs show correct voltages.  Have tried different slots.
Bad relay or transformer winding?
jsteiger
Possible misplaced resistors around the input transformer or 2 transistor discrete follower. Or maybe something is wrong with the relay circuit and both +/- legs are not being switched over properly?
GrantB
To isolate the problem, I removed the input relay, jumped the signal across the relay I/O pins, and removed the input transformer.  Same resulting AC voltages on the inputs as before.  Now only R71, R72, R73, C39, and C38 are in circuit , and they all measured  in spec with no DC conductance to ground.
At this point, I could only conclude that my interface (Sound Devices MixPre 10T) is incapable of driving  this resistor network without drooping ~2mV rms, despite the professional-sounding spec of +18dBu balanced outs.
So after putting it all back together, I buffered my test signal through a ML2 and voila, TP1 = 5.94 mV, unit is outputting +7.75 dBu.
Now I am left with two questions:
1. What is the intended input impedance of this compressor?
2. Can my input resistors be increased to be more compatible with my interface while maintaining compatibility with transformer balanced outputs, and if so with what values?
jsteiger
The input Z of the FC526 XFMR is about 4k5. Any respectable pro audio device should be able to drive that like it's not even there.
I ASSume your interface would sh!t the bed when looking into an LA2A or 1176 or anything with a 600 ohm input impedance?
I would not change anything on the comp. Just slightly increase the level from your interface.
GrantB
Thanks Jeff.  Yeah I just started playing with REW and so far this interface has been a bust for that use.  I've been using a synthesizer through a DI box and my multimeter to calibrate 500 modules so far with no problems.
Yannis
Re: [BUILD] CAPI FC526~500 Series~FET Limiter Kit~Official Support Thread
« Reply #490 on: December 11, 2020, 09:32:16 AM »
I was OK with the built and the use of both the VP312 and the VP28 which are really nices units,  but I'm more in trouble with the FC526XFMR.
I had two problems first. Frist I fried the DTO5 with a bad testing move. I replaced damaged resistors and transitors and it seems OK now. I have put 5089 to match the Hfe of provided 5088, my 5088 have a lower Hfe
The other issue was leds went crazy. I figured out there was a shortcut in the ribbon cable so I soldered it directly on the board and it seems OK too
But it's always not OK the beginning of the audio path seems to be OK :
TP1 : 5.7 mVAC (expected : 5.8)
TP2 : 123 mVAC (expected : 117.7)
TP3 : 983 mVAC (expected : 939) (maybe hot)
TPP 9 : 9.99 V DC so OK
MTR point #11 : 2.5 V DC so OK
But I have nearly nothing in TP4 and next.
The output is a little hot : Module's outtput : 8.09 dBu (expected : 7.75) maybe because of the 5089 transistors
And the release pot leads to a big strange volume reduction when it goes towards CCW
What does I need to check between TP3 and TP4 ? A similar question had been requested in the post #444 of this thread but I can't find anwers.
Help would be much appreciated thanks !
« Reply #491 on: December 14, 2020, 04:58:22 PM »
I'm going to jump in with my most pressing concern and likely roll into other possible issues with my builds.
I've got two (2) FC526-XFMRs completed and started on the calibration process this morning.  I did not get very far and have given up for the day.
My first concerns have to do with getting the correct signals into the units and monitoring the output correctly.  I only have Pro Tools and a Fluke 117 meter.  I have adjusted the Advanced Meter Type Settings so that 0dBu = -18dBFS.  For Q Bias of VVR, I thus set the output of my signal generator to -48dB (producing a graphical meter reading of -30dB) and matched the incoming signal out of the bypassed FC526 #1 through my mixer/mBox Mini to produce a matching -48dB.  With input and output pots set to max, attack and release at the fastest, 20:1 selected, the output was around 7.1-7.2dBu (or -10.8 to -10.9dB).  Turning RV2 CW until it did not change did very little, the steady level was about -7.2dBu.  I opted to set the bias voltage per the reading from the plastic bag and dialed in RV2 by measuring the DC voltage at TP7.
The second FC526 gave an output right in the correct range per the Calibration guide 7.8dBu or -10.2dB.  I double checked against the bag value at TP7 and tweaked to match.
I then moved onto the meter calibration.  Going back and forth between RV8 and RV1 does not appear to be getting the meter to calibrate per the guide's instructions.  If I set RV1 to the specified 2.487V at TP10, all of the LEDs go out, as is to be expected.  The instructions for then adjusting RV8 have the opposite effect on both of my units; with the GR toggle on, turning RV8 CW increases the measured voltage at TP10, while turning it CCW decreases the voltage.  Decreasing the voltage also makes the LEDs come back on.  This is opposite of what the directions say needs to happen.  Further, there is no appreciable difference in DV voltage at TP10 when GR is turned on or off.  I'm left going back and forth, adjusting RV1 to 2.487 and RV8 to 2.252.
Basically, I'm not convinced I'm performing the calibration procedures correctly and would appreciate any help either Jeff or anyone else in the thread could offer.
Thanks.
EDIT:
I identified a resistor error, 470R/4k7 swap, in the DTO5 of unit #1.  The input transistors were running hot and sure enough, there it was.  Will be fixing that issue and hopefully will permit easier biasing of that unit.  #2 is fine for biasing.  Meter is still a question mark for both.
EDIT 2:
I do not believe gain reduction is working on either unit.  I realized that the meter calibration was failing because there was no input signal being attenuated by the unit.  Input and output controls end up at 1 and 10, respectively, but do not yield a 7dB reduction of input.  Essentially input and output are the same with GR switched to on.  Ugh.
EDIT 3: TP09 value for each unit: -9.99VDC, -10.04VDC.
« Last Edit: December 15, 2020, 10:32:09 AM by Dr.Weezil »
« Reply #492 on: December 23, 2020, 11:26:43 PM »
on a scale of one to boned would I be if I fired up this module upside on the jig? :o
Didn’t sound right and quickly unplugged and re orientated..notifying quickly the error of my ways....fired it up no smoke & the pre calibration test points on the meter board check out however when going into Qbias and flipping to active but it’s overloading instead of hanging around -5dbfs.
Going to start going through the board checking for any resistors that may be out of place but wanted to know if any particular area I should check/would’ve been blown since I flipped it around like a dumb dumb  :o :o
« Last Edit: December 23, 2020, 11:32:48 PM by geardude »
Yannis
« Reply #493 on: January 01, 2021, 10:59:14 AM »
Hello !
What should I test between TP3 and TP4 ? which one is the HP filter capacitor ?
Last post December 15, 2020, 12:36:42 PM
by WFDE
Last post December 06, 2020, 11:55:01 AM
by Vibrowhatzit
Last post December 23, 2020, 01:57:59 PM
by Mylithra
Last post July 21, 2020, 09:15:43 PM
by mcdavis
