Homestudio
Active member
- Joined
- Feb 5, 2017
- Messages
- 32
Thanks Jeff
Hey Jasonjasonashworth said:Hello— I'm not sure if this is the right place for this question. If not, I'd appreciate anybody directing me to the right place.
Essentially I am hoping to build the CAPI FC526 compressor. I have seen the red text warnings mentioning the difficulty, and wanted to inquire a bit about this.
I have never built a DIY audio electronics kit. I have, however, built some simple synthesizer circuits on proto-PCB from schematics I've found online, and have CNC milled some circuit boards of my own. I would say I have a decent understanding of basic electronics/circuits for somebody who didn't study this in school, along with pretty good soldering skills. I'm also able to follow instructions carefully.
Knowing this, is there anything that might prevent me from being successful on this build? Other than crowded components and a careful calibration process, what makes this a difficult build? I've seen people describing issues here and there on this thread, but each seems to be unique to the person and eventually conquered.
Any thoughts or input is greatly appreciated.
Jason
Maybe its a meter resolution thing? Try using a 400Hz tone instead of 1kHz. If the DTO5 is getting hot I would look at that PCB. Something must be wrong there. It honestly seems like there are maybe multiple things going on which makes it very hard from this end.Homestudio said:Well Jeff, I feel like a noob. Well I guess I am, this is my 4th build.I tested the fc526 without the jumper last night before your reply. Tested -10.02V DC at TP9; +2.502V DC at MTR point 11. Applied 1kHz sine wave @ -30dBu. Read .024 at input & output. All good readings. Started the Q bias calibration and read deferent than specs, so tested tp1 and read 0's. Figured it was the jumper so installed the jumper... fired back up and I'm reading 0's at tp9; at meter Point 11 zeros at TP1 zeros. The DT05 over heats. I must have fried something. Any advise on where to start looking? I know your on vacation so take your time getting back and enjoy.
PR3 goes to the +V pin of the DTO5 and nothing else. Maybe you have a small solder bridge to the ground plane or something? If to wasn't there before and is now it is indeed a solder type issue.toga said:Hi,
PR3 burning was attributed earlier in this thread to an error on the DTO5 board. However, PR3 is now burning up on power-up with opamps removed.
Any thoughts? All components' placement/orientation checked.
NB. DTO5 (I-) terminal is jumped to R27 replacing destroyed tracking. Just noting this, though the PR3 issue existed prior to broken tracking.
I don't see how that could but I have never done that myself. The jumper is really only related to the DTO5 amp so should not have taken out the other DC rails.Homestudio said:Jeff, do you think that when I did the tests, then installed the gar2520 and continue testing without the jumper installed, screwed something up?
They are listed here. Just make sure you tell me you need the vertical version for the XFMR comp build.Homestudio said:Hey Jeff, I can't find anything obviously wrong with the build. I'd like to replace the DT05 since all was good until I installed the jumper. How would I purchase one? I can't find it in your store. Thanks
Not all DMM's can accurately measure a 1k sine wave. Maybe try using 200Hz or 400Hz. You could also check the specs on your DMM to see what its capable of.Homestudio said:Hey Jeff, I just got back to working on the unit so far the pre calibration numbers are fine.
T9 = -10.02 V dc
MTR piont 11 = +2.502 V dc
Insert a good gar 2520 and power up.
Send 1000Hz sine wave @ -30 dBu = .024 volts in and out. All good.
I flip the bypass to act and get 17.20 volts with slight fluctuations. Now if the convertion program I'm using is correct that's about +26.92 dBu.
The needed +7.75 dBu = 1.89 volts. Is this correct?
What are your thoughts. Thanks
