They sound quite different. The inductor version produces a peaking response just like the mid section. In fact its frequencies overlap a significant portion for the mid band range. The peaking response is great for emphasising a defined range of frequencies and if you use it on a mix you can emphasize individual instruments for example. The RC hi boost is a shelving type so it emphasizes a much wider range of frequencies which is useful for adding 'air' to a mix for example.
Ian, this is very valuable info!!! Thank you!
And since we're at the topic of sound, could you tell us is, in this design, the tube makeup gain too coloured for mastering jobs, or just gentle and transparent enough not to impose too much of its personality?
I would certainly go for tube output stage, but I'm exploring options since I'd like to build it as a dual mono unit so it can be used in mastering also...
I know it's too subjective question... but I had to ask... sorry
Luka
