One side is hotter than the other and you can't trim it out
mjrippe said:Most likely they are trims for the opamp gain settings. Two will adjust the outputs for +4dBm and two for -10dBu. Since the ones on your board are relatively closely matched pairs, why do you think it has been "manipulated"?
musika said:Variable resistors read as follows (still sealed):
VR102 - 14.62K
VR202 - 13.86K
VR104 - 5.32K
VR204 - 5.05K
cray said:because they are not matched or similar values. i think they are manipulated.
also the trimmers have signs .
