Although I still own venerable LEA stuff (generator with calibrated attenuator - 1dB steps from -70 to +22 and Qualiscope - THD meter with built-in tuning oscilloscope), I would recommend using the RMAA software. The only limitation is the soundcard; most soundcards are unbalanced and have limited input handling and output capability. If you can afford a good soundcard with balanced outputs, that would probably be the best long-term solution.thekid777 said:Hi,
I'm in France-Eu and searching for these items to calibrate some gear,
could you please recommend me good affordable ones? (I can buy second hand)
Thanks for your advise!
best,
Julien
