helterbelter
Once again some things to get rid off....
If interested, please send an email to  paulbeltman at yahoo dot com, my PM box is full,
Payment through IBAN banktransfer if possible., but Paypal is possible.
SSL SL555f talkback amp with LMC limiter. tested and working. make an offer.
SSLTech 9k micpre
PCB, stuffed, tested and working. needs +18/0/-18v plus 48v in case needed. I'll add a 2nd board that needs troubleshooting for free.
35 euro plus shipping
DOA, MOD-1,
I've got 16 of these, built for a project that never happened. Tested and working. 2520 compatible.
make an offer.... for 2, 4, 8, 16, whatever.
Lexicon LXP 15
with V1 and V2 chipsets (V2 is currently fitted).
Looks pretty beat up, but functions fine.  75 euro plus shipping (it's fairly heavy though, I'd say EU only !).
Mosses and Mitchell TT patchpanel.
88 points, 48 points are wired to Dsub25.  (3x top row and halfnormalled to 3x bottom row). The other patchpoints can be soldered to your needs.
If needed I can also add some multicorecables, but this will increase shippingcosts significantly. I don't have spare patchcables to add though. 80 euro plus shipping.
500 stuff :
-Lindell 77x500 stereo FET compressor. Defective: The right channel doesn't work correctly : For some reason the sidechain detector on the right channel responds extremely, resulting in high amounts of compression on both channels. If you only apply audio on the left channel, this doesn't happen….. Also, the link battery gets drained very fast, so, i suppose this is where the problem lies. But I'm not in a mood for troubleshooting. When used as mono compressor it works just fine. 100 euro plus shipping. PAYMENT PENDING SOLD
-BARTHRK stereo colour palette C2584. As good as new. With 2x 15IPS and 2x HRK Easy EQ Ge plugins, and of course the output adapter. 180 euro plus shipping.
-DIYRE Colour Palette mk2. As good as new. With Discrete Saturation and XPF plugins. 150 euro plus shipping.
Rossi Reamper deluxe
passive . 25 euro plus shipping.
[IMG}http://www.beltmanaudio.com/wp-content/uploads/2019/01/Rossi-B.jpg[/img]http://DDA M series channelstrips.
The line in/micpre section is upgraded with  OPA2604 (it did make a difference here).
I used this 6ch frame for a couple of years for tracking, with the intention to finish it up into a decent but small mixer, but I never came to it.  it's a finesounding box though...
 I'll add a PDF manual that contains schematics, and I have built a few dual strips in 2HE 19"enclosures before, it's fairly easy to do.
 It needs a standard +18v/0v/-18v/+48v PSU
a sidenote :  I'm keeping the larger sifamcolletknobs, but I'll add sifam push-on knobs that are from the DDA instead.
15 euro plus shipping/paypalfees for a pair.  3 pairs available.
« Last Edit: February 11, 2019, 04:53:43 AM by helterbelter »
helterbelter
Re: D-LA4a clone, BBE 802, 51x parts, semi's and other parts
« Reply #1 on: December 26, 2015, 06:49:26 PM »
Updated first post , added many parts. More to come by the way.
DjaiTeam
« Reply #2 on: December 27, 2015, 03:07:43 AM »
Hallo,
Ik neem graag de 51x parts over van je, zijn de brackets volgens de standaard maten?
Zoals je leest kom ik uit Nederland/ Nieuwegein en kan ik het bedrag via ideal overmaken.
Vraagje; zijn de Oep  A262  A2E en in metalen behuizing.
Groeten,
Iwan
helterbelter
« Reply #3 on: December 27, 2015, 04:53:25 AM »
Hoi Iwan,
De brackets zijn qua maatgeving hetzelfde als degene van capi.  Ideal heb ik niet, maar overmaken via Iban kan gewoon. Heeft ook mijn voorkeur trouwens !
De OEPs hebben inderdaad de Mu Metal behuizing, er zit alleen geen sticker op. Ik heb ze ooit van Sahib gekocht, en ze zien er behoorlijk oud uit, maar deden het prima de keer dat ik ze in een experimenteerprojectje heb gebruikt.
DjaiTeam
« Reply #4 on: December 27, 2015, 05:06:43 AM »
Ik heb je gemaild!
Gr
helterbelter
More info about the SSL LCD meters here :
http://forum.sslmixed.com/index.php?topic=931.0
By the way, I'm told these are also used in 8k and 9k consoles.
djn111
Hoi,
Mail gestuurd voor de 100k lin pots, en misschien ook de vierkante knoppen.
Happy New Year
DJN
helterbelter
Hoi DirkJan,
Ik geloof dat mijn emails bij jou in de spambox belanden.... Ik wil graag weten hoeveel potmeters je nodig hebt, en of je er ook Sifam colletknobs erbij nodig hebt.
De ITT switchcaps zijn inmiddels al vergeven. Dat wil zeggen, als freebee met een paar meters.
djn111
Re: SSL meters, SSL LMC card, pots, faders, semi's and other parts
« Reply #8 on: January 04, 2016, 05:01:22 PM »
Hoi,
Verstuur de mail nog eens, kijk ik even in mijn junk/spam ?
Mvg
Whoops
« Reply #9 on: January 09, 2016, 09:39:15 PM »
email sent on SSL SL555f  talkback compressormodules (listenmiccompressors),
if the last board is still available I'll take it.
helterbelter
Re: DAOC , BBE 802, Dual LA4 frontpanel
« Reply #10 on: July 25, 2016, 08:22:25 AM »
First post modified.
Added DAOC and the dual LA4a frontpanel.
DAOC dual analag optical compressor. SOLD
Working, but not entirely finished.
-The meters need to be replaced by proper VU's (unlike the legend, these Sifams are not  VU's but 1mA DC FSD meters. . They work , but they can't be nulled for 0dB gain reduction)
-one of the threshold pots appear to have a different tapercurve. Both need to be 500kLog.
-The frontpanel is a temporary one, the labels are made with a Dymo labelwriter, and the powerlight isn't wired up.
Aside from that, the unit works flawlessly, also in stereomode the channels track very well.
It has 5 or 6 steps (I'd have to check the amount) for different slopes.
I bought the unit without enclosure , and with a defect, including the Edcor audiotransformers and the Antek powertransformer, which is pretty much oversized. I purchased an enclosure plus EH tubes for it, fixed the fault, made large heatsink for the hi voltage regulator, and rewired the whole thing. Also added Majestic12's very nice slopemod PCB's.
I prefer to sell this one only in EU, due to the weight (it's pretty heavy with the Antek tranny). 400 euro plus shipping.
« Last Edit: August 04, 2016, 09:43:24 AM by helterbelter »
j.frad
« Reply #11 on: July 28, 2016, 02:25:17 PM »
emailed about the daoc
helterbelter
DAOC sold.
dual G1176 added, and a few other items.
helterbelter
The dual Gyraf 1176 has a transformer for 230v , so, sale within EU preferred. I do have a 2x115v primary toroidal transformer in case of need.
And speaking of EU : How does 700 euro including shipment within EU sound for the dual G1176 ?
« Last Edit: September 04, 2016, 08:36:41 AM by helterbelter »
helterbelter
Re: various items for sale . 8-26 added: dual G1176: 700 euro EU
« Reply #14 on: September 04, 2016, 08:31:51 AM »
I'm open to offers as well.
Also interested in (partial) trades. I'm interested in :
-DIYRE colour palette Mk2 (built or kit), with or without plugins.
-CAPI VP26 or VP312
-CAPI FC526 (preferrably unbuilt)
-TAC micpre one, Micpre three, EQ One, MS module (unbuilt only)
-SSL 552, 524, or 527 modules.
-DOA kits or partial kits, boards
-any 500 format FET type compressor,  built/unbuilt/or factory made stuff like Lindell or Fredenstein
actually, any 500 format compressor or micpre could be interesting to me.... 51x is also possible.
Just shoot me an email !
paulbeltman[at]yahoo[dot]com
helterbelter
Re: FS/FT dual G1176, SSL EQs, Lexicons, LA4a clone, Elmas,
« Reply #15 on: September 10, 2016, 07:50:26 AM »
First post updated regarding the LA4, and a few other items added.
Cardinen
« Reply #16 on: September 10, 2016, 08:29:26 AM »
Mail sent!  ;)
SSLtech:  "Because not all that matters can be measured, and not all that can be measured matters."
Hawkmoon
PM' send
iturnknobs
PM sent
Cardinen
payment sent!  ;)
Last post July 21, 2007, 08:39:26 PM
by sodderboy
Last post January 21, 2011, 06:00:21 PM
by Rob Flinn
Last post October 06, 2011, 11:02:19 AM
by tzman
Last post May 22, 2018, 01:09:10 PM
by theinfoiatis
