PLEASE bring back the Peerless S217d!!! CJ?? Anyone?
You can buy it from Don Audio.
But it's quite expensive. Maybe it would be cheaper if you can get a few people and ask at cinemag directly.
I could sell from my stock ready-made step-up amplifier modules for Pultec PEQ-1A, the original circuit.
The kit has my hands made interstage transformer(HS-29, Lpri 250Hy or 30kOhm),
amplifier board 20dB (adjustable), output transformer(S-217D), power board.
Working and tested!  $390/1pc.
I have built one Pultec with CineMag one, so keep for my second one to be the same. If I count correctly, we have interest for 11. Should we do this?
FWIW, I did a very thorough listening test between the Sowter and Cinemag S217-D repros and the differences were so minimal I would use either without hesitation.
Hi guys,
Here is a first look at one of our latest projects.
I decided to make a super thin bobbin for this one as we need repeatability and this helps us to do that.
Other than the 0.4mm bobbin, specs are the same.
Tomorrow we will do some tests and see how she performs.
It would be nice to be able to make an S-217D type transformer that was affordable, and had the correct stack and specs.
We are using ni78 C Lam’s rather than L Lam’s but that is just a preferrance thing and gives us more options and uses for the Lam’s .
Might ad a screen tomorrow too.
