bcarso
Hello Folks,
Here is one for circuit connoisseurs and creative types: What is the simplest possible way, barring the use of transformers, to reject noise due to a noisy source "ground"? Let's restrict the bandwidth of the signal and the noise to the nominal audio frequency range, and suppose that the voltage relative to our local circuit common is fairly small, say less than a few hundred millivolts rms. So what we are looking at as a source is something nominally referenced to our system common, with the whole thing bouncing on the noisy ground local to the source (or from the viewpoint of the source, seeing our noisy ground). The impedances of the lines are anything but balanced, i.e., this is a single-ended, nominally "grounded" source. Let's say the source device has an highish output impedance, in the hundreds of ohms range (but not known precisely). Suppose there is maybe an ohm or two and less than a microhenry, at most, between the source common and our common.
How would you do it? As yet undetermined prizes, at least extending to my appreciation and respect, will be awarded for the solution with the best performance/minimal cost. This should be something that does not require adjustment in manufacturing.
Brad
Brad
