I finally got my two channels powered up , sent some signal through and have a minor things.
1.The bypass switch on one channel has no "click" :? - It doesnt work, even if I hold it in. Anything I could check there, or do I "just" need to replace the switch ?
2.Ive seen this mentioned somewhere, but cant find it in any of the threads linked from the Calrec meta - I have a boost with the eq in set flat. Was there any solution for this ? Its not a big deal, but for A/B I would like it to be even.
Gustav
