[quote author="Jonas K:strand"]... i put a little link there and the thing started sounding. ive had it on without this link for some time... can this have damaged any components?
I don't think so. You just didn't pass the signal from one point in the circuit to another... The link was meant for Hi-Lo pass filter insert point or a gain stage if i remember well from the posts that i had read...
....the thing has a bussing sound in the highs now and the sound gets distorted when i tweak on a line signal from a synth, not really sure i wiered things the right way on the ins and outs and ground and ooh...
Shouldn't be sounding the way you described...Are you overloading the input of the Calrec? What about input resistor,"You could try changing the two 10K series resistors at the balanced input to something larger - say 22K should take you down 6dB etc.."quote-Gyraf... Try to look for the misplaced components, shorts of all kinds....Magnifying glass with a lamp is very helpful for this sort of problems, if you are not using one already....
...seems like youre on your own after the PCB´s
as you can read you are not
are there any threads on this? i mean... it should be!
cheerz
/jonas[/quote]
use the "search" function it is very useful. I know very little about electronic, almost nothing, but reading the forum and using the search function i've complited the Calrec project with success.
