erquere
Re: Build Thread:VECA MS (VCA comp)
« Reply #100 on: March 08, 2018, 11:08:02 AM »
Hi everybody ! I bought a pair of the MS VECA  pcbs, may someone have the .fpd files for its frontpanel ?
Best regards from France !
Used to be a journalist but I prefer build comps and eqs
erquere
« Reply #101 on: March 08, 2018, 11:09:30 AM »
(and a question for Gustav : do the rev5 pcbs correct the rev4 pcb errors shown in the errata ?)
« Reply #102 on: June 12, 2018, 06:26:57 PM »
http://www.sugnation.com/VECAF.fpd
http://www.sugnation.com/VECAB.fpd
Hopefully these will help. Sorry it's a bit late!
ToBSn
« Reply #103 on: July 12, 2018, 06:18:36 PM »
Based on the pdf named VECA_ERRATA_4.pdf you need to correct the rev5 boards.
2x left and right crossing traces between the bypass relays.
reverse  tantals on aux board.
100nf cap on the psu section.
2x left and right two in parallel 33k resistors or one 16k  in the side chain section
ToBSn
« Reply #104 on: October 09, 2018, 09:10:13 AM »
Hi Gustav, because i can't find anymore on Your web site, is it possible to receive by personal mail the BOM SCH and Doc in general for Ms Veca and possibly BOM for PQD2 ( other doc still available on Your website)
(order 1285)
Thanks so much for support
« Reply #105 on: January 22, 2019, 04:42:12 AM »
Hi all, please  someone may share the BOM and possibly the schematic of VECA because Gustav ( pcbgrinder) don't provide anymore on website
I may need even the PQD2 ones
i've the pcbs from almost 2 years and now i'd like to assembly my units
Your help will be really welcomed
Roberto
TwentyTrees
« Reply #106 on: January 23, 2019, 04:06:46 AM »
Hi all, please  someone may share the BOM and possibly the schematic of VECA...
Roberto - PM'd.
erquere
« Reply #107 on: February 07, 2019, 05:48:27 PM »
Hi ! I have the whole docs for MSVECA, you can pm me your e-mail i will send it to you
erquere
« Reply #108 on: September 27, 2019, 07:04:43 AM »
Hello ! Has someone the schems of the MS VECA, especially the main board one ? I have all the other pieces for buiding, but not the schems
erquere
« Reply #109 on: October 28, 2019, 07:51:24 PM »
Noone for schems ?   :-[
Last question and I let U still : what does the P position of the release switch mean ? As I don't have schems I xan't find it by myself...
Best regards
deadpoet
« Reply #110 on: October 29, 2019, 02:41:12 AM »
I only now found your post, I have schematics & stuff:
https://www.dropbox.com/sh/yn0bhm1pwdfschc/AAByocmZgJpMiOrpYSklC_Wea?dl=0
Hope this helps,
Herwig
erquere
« Reply #111 on: October 29, 2019, 06:22:18 AM »
Yes it does ! Thanks a lot !!!
Maybe you know what the "P" release position is ?  ;)
gyraf
« Reply #112 on: October 29, 2019, 07:06:15 AM »
maybe like the auto release position of the gssl?
TwentyTrees
« Reply #113 on: October 29, 2019, 07:39:50 AM »
If memory serves, it stood for “Pump” - as in less transparent, more obvious gain pumping.
erquere
« Reply #114 on: October 29, 2019, 07:57:36 AM »
OK thank you ! I just got the schems, I'm going to check that !  :)
erquere
« Reply #115 on: October 29, 2019, 09:07:20 AM »
The P goes to u47 and 6u8 with 1M2 and 180k resistors,
ToBSn
« Reply #116 on: February 04, 2021, 07:36:02 PM »
VECA_ERRATA_4.pdf for Rev5 boards
T.LO
Re: Build Thread:VECA MS (VCA comp) New
« Reply #117 on: February 05, 2021, 04:46:56 AM »
after a few years I started to assemble this compressor. some of the errata changes I did already. some changes were absolutely new to me. There's still some work to do.
thank you ToBSn for sharing the Errata doc 4. I bought the pcb from Gustav, when he already closed the support for this project. I am happy to have a working compressor so far. I still need to change the orientation of the tantalums on the switch board. I also need a dual 10k Lin which fits in the front panel.
I want to thank Gustav for this project and everybody in the group who's sharing knowledge an experiences. You guys are fantastic!
« Last Edit: February 19, 2021, 01:04:48 PM by T.LO »
T.LO
« Reply #118 on: February 05, 2021, 04:52:06 AM »
this is how I corrected the crossed wiring inside the pcb.
