Hi all!
As there hasn't been much feedback on the VECA so far, I wanted to just jump in and say that this is a really fun build and an amazingly flexible compressor. I also wanted to share some of the things I encountered when building mine in the hope that it may help others. I decided to go for this rather than the standard GSSL for the built-in side chain and blend features, as well as the (unique?) mid/side side-chain emphasis – and Gustav has done a great job of bringing all that together into a unit that shares a lot of DNA with the GSSL but is very much its own beast.
I finished building mine over the weekend (still got a bit to do on the aesthetics!), and was surprised and delighted when it worked first time and nothing blew up. I was particularly surprised as I made a few modifications to the design, so the chances of everything working straight off the bat seemed pretty remote (of course, the sensible plan would have been to build the thing first, verify it was working, and then investigate mods – what can I say, I like to live dangerously...). I should note that the fact I carried out mods isn't a reflection on Gustav's design, which as I say is excellent – rather, I know how I like to use compression so wanted to make as flexible a toolkit as possible.
As well as an extra 1.5:1 ratio, I added a bunch more side-chain filter options, a whole load more attack times, and pots for variable attack and release (selectable from the A/R switches). Details at the end. I spent a long time doing my homework, and many hours reading various posts around here, so huge thanks to the whole community for being so giving in sharing info and expertise. The fact that this all worked first time is testament to everyone else's hard work as much as my obsessive research!
I was a bit worried that the additional ratio and other mods might upset the delicate balance of the compressor, so following advice I found around the place (referenced below) I switched a couple of resistors out for trim pots and set out the details here in case anyone else is thinking of doing similar:
- R100: this 2K resistor calibrates the meter, and I switched it out for a 5K trim pot (which I pre-trimmed to 2K)
- R101: this 120 K resistor trims how the ratio is applied at a given point on the threshold (as far as I understand it!), and I replaced it with a 100 K resistor plus 200 K trim pot (pre-trimmed to 20 K) in series
- R4 & R21: these 1K resistors manage the control voltage fed to the left & right channel VCAs from the compression section of the board. In practical terms, they control the range of the ratios - if you increase them above 1K, the ratios bunch up (ie, 2:1 might be more like 3:1 and 10:1 might be more like 8:1), and if you decrease them, the ratios spread out (so 2:1 might become 1.5:1, 10:1 might become 11:1). After extensive experiments, and much twiddling of the 200K trim pot above, I reduced these to around 900R each by strapping a 16 K and 20 K in parallel with each (based on what I had lying around - not elegant, but it works).
Calibration took a while (mostly experimenting with R4 and R21), but after making the changes above, and tweaking the trim pots (using the SB400 calibration guide and the posts by regularjohn, MikeClev and jwhmca linked below), I was able to get the ratios almost spot on:
- 1.5:1 gives an increase of 6.3dB on 10dB input increase, therefore 1.56:1
- 2:1 gives an increase of 5 dB, so 2:1
- 4:1 gives an increase of 2.5 dB, so 4:1
- 10:1 gives an increase of 1 dB, so 10:1
Given how long it took me to get to this point, I will happily accept being very slightly out on the 1.5:1 ratio!
All in all, it's been a great experience from which I've learned a huge amount, and I can't wait to start using the VECA in anger. My thanks to Gustav, and to all those whose good ideas and hard work I have benefited from here. Now to tidy up the wiring, cut down the pot shafts, and sort out the front panel (where did I put that walnut sheet..?).
Andy
Full list of mods:
- Additional ratio: 1.5:1 (see link below for details)
- Additional attack times: 5 ms, 15 ms, 20 ms, 50 ms, 100 ms (using 41.2K, 124K, 165K, 412K and 820K resistors respectively)
- Switchable variable attack, between 0.1 and 30 ms (250K log pot in series with 820R resistor)
- Switchable variable release, between 0.1 and 1.2 sec (1M lin pot in series with 180K resistor - both paralleled with 47uF tantalum cap)
- Side-chain filter frequencies: off, 40Hz, 60, 80, 100, 120, 40, 160, 180, 200, 250
- And the meter LEDs change colour from amber to white when the compressor is bypassed!
Calibration links:
Calibrating the GSSL (regularjohn)
http://groupdiy.com/index.php?topic=40883.msg507502#msg507502SSL clone compressor ratio measurements (MikeClev):
http://groupdiy.com/index.php?topic=944.msg535243#msg535243GSSL 1.5 ratio mod (jwhmca):
http://groupdiy.com/index.php?topic=49854.0SB400 calibration - at the end of the Build Guide
http://groupdiy.com/index.php?topic=40971.0
