Build Thread:VECA MS (VCA comp)
Hi everybody ! I bought a pair of the MS VECA  pcbs, may someone have the .fpd files for its frontpanel ?
Best regards from France !
http://www.sugnation.com/VECAF.fpd
http://www.sugnation.com/VECAB.fpd
Hopefully these will help. Sorry it's a bit late!
erquere said:
(and a question for Gustav : do the rev5 pcbs correct the rev4 pcb errors shown in the errata ?)
Based on the pdf named VECA_ERRATA_4.pdf you need to correct the rev5 boards.
2x left and right crossing traces between the bypass relays.
reverse  tantals on aux board.
100nf cap on the psu section.
2x left and right two in parallel 33k resistors or one 16k  in the side chain section
ToBSn
Hi Gustav, because i can't find anymore on Your web site, is it possible to receive by personal mail the BOM SCH and Doc in general for Ms Veca and possibly BOM for PQD2 ( other doc still available on Your website)
(order 1285)
Thanks so much for support
Hi all, please  someone may share the BOM and possibly the schematic of VECA because Gustav ( pcbgrinder) don't provide anymore on website
I may need even the PQD2 ones
i've the pcbs from almost 2 years and now i'd like to assembly my units
Your help will be really welcomed
Roberto
Hello ! Has someone the schems of the MS VECA, especially the main board one ? I have all the other pieces for buiding, but not the schems
Noone for schems ?  :-[
Last question and I let U still : what does the P position of the release switch mean ? As I don't have schems I xan't find it by myself...
Best regards
I only now found your post, I have schematics & stuff:
https://www.dropbox.com/sh/yn0bhm1pwdfschc/AAByocmZgJpMiOrpYSklC_Wea?dl=0
Hope this helps,
Herwig
  • VECArev5schem.pdf
after a few years I started to assemble this compressor. some of the errata changes I did already. some changes were absolutely new to me. There's still some work to do.
thank you ToBSn for sharing the Errata doc 4. I bought the pcb from Gustav, when he already closed the support for this project. I am happy to have a working compressor so far. I still need to change the orientation of the tantalums on the switch board. I also need a dual 10k Lin which fits in the front panel.
I want to thank Gustav for this project and everybody in the group who's sharing knowledge an experiences. You guys are fantastic!
