Gentlemen,
I may have just what you're looking for. I'm just finishing up a 500 style rack using original 2520's. The PCB's fit in a standard 5.25 by 19" rack. The power supply card fits as well with external power transformers. The power supply can run 2 bipolar supplies and also has phantom. The mic pre card has front panel mic in, line in, 20dB pad on mic , 12dB pad on line in, phase reverse, and phantom switch. The boards fit JE115 xfrms and either the API or Jensen output transfomers. It also has an 8 segment ajustable LED VU meter. I can fit either 8 mic pres and power supply card or 10 mic pres (with power supply external with toroids). The first mic pre has been tested and works very well. I'm waiting for the first single unit test front panel to make sure everthing fits. Once this is done I can commit the rest of the panels and the backplane PCB design(64 pin DIN connectors) so all modules slide in and mate and fit within the 19". The backplane also allows for rear panel mic connections.
Here's the catch. I've also designed my own discrete amplifier block that fits into the standard footprint. This was quite an undertaking and I should have some results on this item is just a few weeks. If it sounds and specs good (must be better than good!) I may market them. If the opamp doesn't work well.......well then I may just offer up some of these boards if someone is interested. It all hinges on the opamp.
Anyway, as soon as I get the front panels back I'll post some pics of all the pieces. I can tell you that it's not an easy job to get all this to fit in a 1.7" X 4.5" X 6" PCB and put 8 of them in a rack with a regulated power supply along with it.
I'll keep update soon.
Best Regards,
Jeff
