dacapitan
Hello - I just completed this build with the Gyraf SRPP board and Franks Filter board. I took a sweep using RMAA, with no boosts or cuts and this was the result. I am a bit of a novice so I am not entirely sure if this result is normal or an issue that I need to fix or if they are negligible,
I noticed there is quite a large boost below 100Hz and there is a 0.25-0.4 db difference in the left and right channel, Im not sure how the noise and THD etc fairs against the benchmark?
so I would appreciate any insight anyone would be able to provide.
