Deepdark
Quick one for you guys.
I'm finishing an Federal am864. I had question about the heaters wiring. I didn't wire them the way it is one the schematic, i found it to be a little on the weird side. I did it the classical way, using a center tapped coil. So i tightly twist a pair of wire. One will take the 2 6sk7's pin 2s, the 6sn7's and 6sq7's pins 7. The other one take the 2 6sk7's pins 7 and 6sn7 and 6sq7's pins 8. What if, for exemple i reverse one? In my understanding, it will change nothing since they are in series, no matter which way we connect it. Why, in the original schematic, for exemple 6sk7's pin 7 are connected to the fillament and pins 2 to gnd, and 6sq7 /6sn7 pins 7 are filament and pins 8 are gnd? Why not 6sk7's pins 2 to filament and pins 7 to gnd? Idoes it eeally matter?
