SSL Summ Unit with SSL input modules and "Ne-vish" L- R bus
r2d2
A-rea 51
Hi everybody ,
have a chance to get 16 ch of SSL input modules (check image attached)
as a "trade/exchange"with some audio device ,
the "temptation" is to accept the trade offer and use the SSL input modules as mic-line pre
for recording from sources to the Daw ,
and also as Summ Unit ,
connecting the Daw  DA converter (outputs) to the line input of the SSL modules
and send all input to a L-R  Summ Master bus module ,
a la "Ne-vish"  vintage console (that with 1073 or 1081 modules)
checked a lot here in the forum and googling  on the web  ....
but not found  "good" helps  or docs ,
about :
SSL inout modules schematics and connector pins map/layout
Neve L-R Master summ bus schematics
I am also considering the possibility for a SSL  L- R Master summ bus
or Api ,
any help is welcome
thanks in advance for anything about
R.
Neve is single ended +24V, SSL uses +/-18V.
A Classic API ACA-2 summing board would work fine with the same PSU though, use GAR2520 op amps for an API flavour or hairball 990 op amps for a more neutral discrete option. There's also the APP992 op amp and lot's of others, obviously.
many thanks for post "living sounds"
you are right about power voltages
and  thanks for summ type info ,
unfortunately before all schematics are required for check connections
and also if possible take the signal to send to  L - R summ bus
before the output stage
R
