Balancing/Debalancing
Infernal_Death
Germany
Hi all
Right now i work on my first project and i need to debalance the input signal and after balance it once again.
Now as i am a newbie at this stuff i looked around and thought i could use the input and output stage of Jakob's Calrec.
I just copied this out of Jakobs schematic. Is there anything wrong with this ?
The empty rectangle is the project i want to build and it needs unbalanced input and has unbalanced output.
And please ignore the bypass switch as i will implement the bypass another way.
I plan to use 1 5532 for this task.
And lastly i hope it's ok for me to use Jakobs design.
Flo
Thanks Jakob. I am really at the beginning of all this so i don't know how and if it will work out.
Even if it won't work out i am sure i will learn much :green: :thumb:
Flo
