Rob Flinn
Re: Best way to punch IEC panel mount connector in boxes.
« Reply #40 on: April 05, 2018, 11:22:58 AM »
With Greenlee punches you should not only lubricate the threads but also liberally the cutting edges too, it helps keep them nice and sharp.   After all with a  mill or lathe you lubricate the cutting parts too.
I use the 4x  10mm holes & a jigsaw method, mainly because I have them. Having done this a few hundred times now I can actually get it pretty close with the jigsaw so filing is kept to a minimum.   I would try a dremmel if I had one.
I have a bunch of round punches but as we know the rectangular ones are a lot more expensive.
regards Rob
mutterd
« Reply #41 on: May 02, 2018, 08:40:26 PM »
Hey Jacob - what IEC connectors have you used with this punch - im thinking of making the plunge but i have been sifting thru the fused sockets and havent found a match. Just want to see what my options are.
thanks for the tip!
Timothy
It's supposedly a Greenlee 50125036  - and I haven't seen it any cheaper anywhere..
https://www.alliedelec.com/rs-pro-542302/70639688/
Jakob E.
buildafriend
« Reply #42 on: May 13, 2018, 04:07:10 PM »
You can look at the shape of the punch and then compare it to available IEC inlets aka power inlet data sheets. It didn't take me long to find some matches..
gyraf
« Reply #43 on: May 14, 2018, 02:37:21 AM »
Aah, sorry - it's for e.g. this one:
https://www.monacor.com/products/components/cables-and-plug-in-connectors/mains-supply/aac-150pf/
..but there are many of that type on the market, that will fit the tool cutout..
Jakob E.
..note to self: don't let Harman run your company..
« Reply #44 on: May 14, 2018, 03:57:34 AM »
I have looked at the RS web site and i an a little confused as to how you would operate this punch. The ones I am familiar with use a chunky Allen key but this one seems to be different.
abbey road d enfer
« Reply #45 on: May 14, 2018, 04:50:08 AM »
Far as I can see, this one uses standard hex keys, which seems a more robust and versatile option than Allen keys.
Who's right or wrong is irrelevant. What matters is what's right or wrong.
Star ground is for electricians.
gyraf
« Reply #46 on: May 14, 2018, 01:47:56 PM »
Mine just uses a 19mm spanner. And I got an axial pressure bearing for it, to make work a bit easier
Only catch is that you need a 16mm pilot hole
Jakob E.
edit: 19, not 15mm
« Last Edit: May 15, 2018, 03:48:20 AM by gyraf »
« Reply #47 on: May 14, 2018, 06:22:34 PM »
Jakob E.
For which you probably need another punch!!
abbey road d enfer
« Reply #48 on: May 14, 2018, 06:44:21 PM »
At the beginning of last month, I bought ready-made custom holes from a specialized vendor; however the cost of p&p is prohibitive.  ;)  :-[
gyraf
« Reply #49 on: May 15, 2018, 03:49:42 AM »
yeah, I hear you - but I had to upgrade my bench drill to get to the 16mm. Only later to discover the idea of reduced-shaft drills  ::)
Jakob E.
abbey road d enfer
« Reply #50 on: May 15, 2018, 05:34:12 AM »
Jakob E.
I guess my tentative at nonsense just got unnoticed.
At the beginning of last month, 1st of April I bought ready-made custom holes holes, really?  from a specialized vendor; I guess if you google "holes for sale", you don't get many answers... however the cost of p&p is prohibitive. Indeed, what type of container is likely to pack holes?
« Reply #51 on: May 15, 2018, 06:28:51 PM »
LOL, I thought you meant you had paid Frank to make the panel for you. He sells holes of all sizes and shapes you know.
Gene Pink
« Reply #53 on: May 15, 2018, 08:50:53 PM »
I figured you were going there, but missed the date reference.
If you need holes, I heard that the Albert Hall is full of them, authentic holes from Blackburn, Lancashire. Thousands of them. ;D
abbey road d enfer
« Reply #54 on: May 16, 2018, 03:51:29 AM »
I know, but according to the reporter "the holes were rather small", and I don't know when they'll be available, cause "they had to count them all"...
abbey road d enfer
« Reply #55 on: May 16, 2018, 03:57:15 AM »
customholes.com!  ;D
gyraf
« Reply #56 on: May 16, 2018, 08:39:02 AM »
 ;D
« Reply #57 on: May 16, 2018, 03:09:18 PM »
customholes.com!  ;D
ROFL. Nice one Abbey.
« Reply #58 on: May 19, 2018, 05:46:40 AM »
customholes.com!  ;D
I am VERY weary to click on this link at work!
abbey road d enfer
« Reply #59 on: May 19, 2018, 07:06:41 AM »
I've been informed that the sitenow  accepts only pick-up orders.;reason is they had a problem, the truck carrying large holes went into a pothole and lost part of the cargo. In retreating to recover, the truck fell into the hole.  :(
