benqbasic said:Hey Buddy,
Would be interested to here how it sounds without the transformers.
I have been meaning the make up a 2503 part for eagle for a while now.
I believe the layer 46 - Milling is what you want for the transformer slot. I think you can use the dimension layer 20 as well.
Ben
abbey road d enfer said:Note that when you use an output transformer, you need to feed it with the lowest possible impedance and make sure theer is no DC current. You may want to trim DC offset of the DOA.
Inject DC in the inverting input via a 1Meg resistor. Use a 100k trimmer between + and - rails.ForthMonkey said:abbey road d enfer said:Note that when you use an output transformer, you need to feed it with the lowest possible impedance and make sure theer is no DC current. You may want to trim DC offset of the DOA.
If i use transformer,i won't install other output components.It will close to original design.Sould i add DC offset control?If i have to add,how do you suggest?
abbey road d enfer said:Inject DC in the inverting input via a 1Meg resistor. Use a 100k trimmer between + and - rails.ForthMonkey said:abbey road d enfer said:Note that when you use an output transformer, you need to feed it with the lowest possible impedance and make sure theer is no DC current. You may want to trim DC offset of the DOA.
Correct. Now I would make the circuit a little more complicated, just to make sure it does not introduce noise..ForthMonkey said:Thanks for advice.I was looking for dc offset circuits.Now i added trimmer and resistor.Is this ok?
abbey road d enfer said:Correct. Now I would make the circuit a little more complicated, just to make sure it does not introduce noise..ForthMonkey said:Thanks for advice.I was looking for dc offset circuits.Now i added trimmer and resistor.Is this ok?
Just draw the cut-out in layer 46 (it generally works even in layer 20).ForthMonkey said:Updated first post.Added components for DC offset.
Still no idea about cutting inside of PCB to fit transformer.
abbey road d enfer said:Just draw the cut-out in layer 46 (it generally works even in layer 20).ForthMonkey said:Updated first post.Added components for DC offset.
bruno2000 said:I use layer 20 and use the "tname" layer with the words "cut out" in the rectangle to be removed. This has worked every time so far with 1 US and 2 Chinese board houses.
YMMV
Bruno2000
ForthMonkey said:bruno2000 said:I use layer 20 and use the "tname" layer with the words "cut out" in the rectangle to be removed. This has worked every time so far with 1 US and 2 Chinese board houses.
YMMV
Bruno2000
Thanks for idea Bruno2000.
You meant this?
