culteousness1
Re: Discrete OpAmp Test Jig
« Reply #20 on: April 04, 2016, 02:19:10 AM »
I am sorry I can't provide a  solution that doesn't include cutting traces.
If there is interest, this is something to incorporate in a revision along with a corrected footprint for the switch  ::)
Carsten
"What's all this analog stuff anyhow?" - Bob Pease
"My favorite programming language is ... solder." - Bob Pease
kante1603
« Reply #21 on: April 04, 2016, 12:39:27 PM »
maybe this will do the trick?….sorry,don´t know where the 7th pin is located….
Built in ten minutes with veroboard,solder nails and sockets.
Best regards,
Udo.
Edited typo….
« Last Edit: April 04, 2016, 12:47:22 PM by kante1603 »
kante1603
« Reply #22 on: April 04, 2016, 12:41:31 PM »
…another view angle…..
kante1603
« Reply #23 on: April 04, 2016, 12:42:48 PM »
….from top…..
kante1603
« Reply #24 on: April 04, 2016, 12:43:45 PM »
…and bottom…
hope this helps?
kante1603
« Reply #25 on: April 04, 2016, 12:56:42 PM »
With a DOA plugged in,to give you an idea…..
API
« Reply #26 on: April 05, 2016, 09:14:20 AM »
Thanks for the great suggestions!
Anyone know where you can buy those sockets with standoffs here in Europe?
culteousness1
« Reply #27 on: April 05, 2016, 09:50:20 AM »
I have to agree, Udo came up with a clever  creative solution I didn't think of  :o
If Farnell is an option for you, you can copy-paste the order-code from the BOM in their search mask  8)
Otherwise I can only suggest to drop Volker a mail...
Carsten
kante1603
« Reply #28 on: April 05, 2016, 12:24:23 PM »
Carsten
Yes,asking Volker is a good idea,he helped me with sockets and pins several times.
@ Carsten:Danke für die Blumen ;D
Udo.
culteousness1
« Reply #29 on: February 09, 2017, 12:25:51 PM »
I finally reviewed the board and ordered a new batch:
The rotary switch fix is no longer needed  8)
Please see my BM listing to order some spare boards.
Carsten
[EDIT: FIXED LINK.]
« Last Edit: March 16, 2017, 01:52:41 PM by culteousness1 »
kante1603
« Reply #30 on: February 09, 2017, 01:41:04 PM »
Very nice again Carsten!
Best regards,
Udo.
elskardio
« Reply #31 on: February 09, 2017, 05:39:22 PM »
PM sent for 1 board.
culteousness1
« Reply #32 on: December 04, 2017, 03:14:14 PM »
I just got a question about the switch positions and their functions via PM, so I thought I would answer here for all:
Switch positions 1 and 2 are a non-inverting amplifier with unity gain and +20 dB, respectively. The other two switch positions configure the DUT as an inverting amplfier with either unity gain in position 3 or +60 dB gain for position 4. The silkscreen has these switch position printed on as well.
Hope this was clear enough  ;D
Carsten
