pahstah
Re: DIY Modular Mixer
« Reply #60 on: March 17, 2016, 02:26:45 PM »
Hi Pahstah
What an nice work !!!
"DIY" definitely step up recently with Ian/Holger tube mixer and now yours.
Looking forward to retrofit a moving fader system  ;)
Best
Zam
Zam, that would be the icing on the cake!
I'm already thinking  about a version of this mixer with a separate fader bucket for your moving faders
This forum and its member are the best!!!
Paolo
 P.s. Let's not forget Gary 's Sphere
« Last Edit: March 26, 2016, 04:44:56 PM by pahstah »
pahstah
« Reply #61 on: June 27, 2016, 06:10:16 AM »
mixer's done! loaded with 8 helios 69, 2 nv 1073, 2 aphelios, and 4 capi vp28 as line input. i solved the noise problem in the summing part of the console and i've found that aux sum is has less noise than group and 2bus sum!
beatnik
« Reply #62 on: June 27, 2016, 07:35:17 AM »
good job !
Timothytitus88
« Reply #63 on: June 27, 2016, 07:50:16 AM »
Indeed! just marvelous!
T
iprovlek
« Reply #64 on: June 27, 2016, 07:58:12 AM »
Great Pastah! 8) 8) 8)
Rocinante
« Reply #65 on: June 27, 2016, 10:16:32 AM »
Congratulations!  What an inspiration!  Looks beautiful!
If there's a harder way to do this, I haven't found it yet.
audiomixer
« Reply #66 on: June 27, 2016, 10:20:40 AM »
I like it a lot, great looking piece of kit!
- michael
« Reply #67 on: June 27, 2016, 12:03:05 PM »
Hi Pahstah
Absolutely great !
Bravo !!!!
Best
Zam
benqbasic
« Reply #68 on: June 28, 2016, 02:18:08 AM »
Wow that thing looks fantastic. Nice work
pahstah
« Reply #69 on: June 28, 2016, 07:17:10 AM »
Thank you so much for the appreciations guys!
her's a shot of the helios channels
anjing
« Reply #70 on: June 28, 2016, 09:58:50 AM »
beautyfull work....what did you use to close the gaps between the buckets?
Regards,
Pierre
pahstah
« Reply #71 on: June 29, 2016, 04:36:42 AM »
Hi Pierre,
there is no gap between the buckets because these are two buckets put together with screws
in this image you see the 8 channel bucket on the right but in the previous image you see that i've put the 8 channel bucket on the left.
I could have made a 16 channel mixer directly with the right length of rails but at the beginning i was going for an eight channel mixer
paolo
Paolo
« Reply #72 on: April 17, 2017, 07:33:02 AM »
Hello!
Old thread I know, but worth a bump anyways.
Beautiful build. I was wondering; if you don`t mind, why not post pcb and metalwork drawings/schematics here? I know I would appreciate it to use as starting points for designing my own modular mixer. Maybe you have .fpd and pcb files even? So much learning potential  8)
