Bunch of random weirdo units, parts and pieces
emrr
NC, USA
Offers considered on any.
In this issue:
new Ross rack mount power distro
Alesis AI-1
Rane AVA 22 stereo broadcast delay
Altec 449A amp w/ 533A PSU, 538A PSU
Western Electric 359B Equalizer
Gates M6031 mounting tray for M5700 amp, RCA BA-71/72 type connector
RPM tube regulated PSU
Di-Tech +/-28VDC PSU, for Quad Eight?
NOS Ross R-21 2RU AC power panel.  2 fused continuous outlets and 5 fused switched outlets.  Maybe U need?
$offer$ plus shipping/insurance on 10 lbs.
Alesis AI-1
With manual, original box, no operational problems noted.  Front panel selects sampling rate conversion (if desired), source type, destination type, ADAT pair (if required).    This is a pretty handy box to have around at times.
ADAT sync in/out
Word clock out
ADAT optical in/out
S/PDIF optical and RCA in/out
AES/EBU in/out
$75 plus shipping/insurance on 22/10/5 box, 7 lbs shipping weight.    Offers considered, these seem all over the place.
Designed to facilitate audio to video offset correction, this stereo digital delay unit uses Dolby Time Link 1-bit delta sigma conversion for AD/DA.
These are also great for simple pre-delay to analog plate and spring reverb units.  It switches in half video frame increments, in PAL mode you get 20mS increments up to 320mS, in NTSC you get 16.68mS increments up to 317mS.  When linked for stereo, the two channels change with one another, de-linked get separate operation, which can obviously be daisy chained for longer and finer times.  It is a unity gain device, which provides a sensitivity trim to compensate for varying input levels.  I have a few available, these have been tested and work properly.
These units lack the RS1 PSU, usually numerous used pieces on ebay under $50.  18V CT AC, 750mA.
Quick data sheet here:
http://www.rane.com/pdf/old/ava22dat95.pdf
Manual here:
http://www.rane.com/pdf/old/ava22man95.pdf
2N191 transistors.
$25 plus shipping/insurance on 4 lbs
Western Electric 359B Equalizer with two 2543K transformers, 50Hz-70kHz 150:600
$30 plus shipping/insurance on 1 lb.
Use it for a Gates M5700, or rob the Amphenol Blue Ribbon connector off it for your RCA amp.
$15 plus shipping/insurance on 1 lb.
5R4, 6BX7, 0G3, (2) Raytheon 12AX7.  50-150VDC.  Heavily shielded cast aluminum enclosure around power transformer.  No other information.
$30 plus shipping/insurance on 12 lbs
Heavy duty regulated PSU from an audio distribution rack system.  Not sure of current rating other than 2A mains fuse, you do the math.  It’s a plug in module, and the mating panel with mains cable, fuse, and DC distribution terminals is included.
offer$ plus shipping/insurance.
Doug
Really interested in that Alesis ADAT switcher
Pay day at the end  of the month... if its still there then will take it of your hands
If it's still in the listing, it's still available.
Be sure to PM me, notifications are not working and I might not see anything said in this thread!
