Alternative Transistors for 2SC1681 and 2SA561
Humner
Sydney Australia
I'm looking for alternatives/replacements for 2SC1681(NPN) and 2SA561(PNP)
My guess is that I shouldn't have any issues going with BC550 for 2SC1681 and BC560 for 2SA561 ?
Type Designator: 2SC1681
Material of transistor: Si
Polarity: NPN
Maximum collector power dissipation (Pc), W: 0.2
Maximum collector-base voltage |Ucb|, V: 60
Maximum collector-emitter voltage |Uce|, V: 60
Maximum emitter-base voltage |Ueb|, V: 5
Maximum collector current |Ic max|, A: 0.05
Maksimalna temperatura (Tj), °C: 150
Transition frequency (ft), MHz: 65
Collector capacitance (Cc), pF: 5
Forward current transfer ratio (hFE), min: 200
Package of 2SC1681 transistor: TO98-1
Type Designator: 2SA561
Polarity: PNP
Maximum collector power dissipation (Pc), W: 0.3
Maximum collector-base voltage |Ucb|, V: 50
Maximum collector-emitter voltage |Uce|, V: 50
Maximum collector current |Ic max|, A: 0.15
Maksimalna temperatura (Tj), °C: 125
Transition frequency (ft), MHz: 70
Collector capacitance (Cc), pF: 25
Forward current transfer ratio (hFE), min: 40
Package of 2SA561 transistor: TO98-1
Hi what did you end up going with if you dont mind me asking?
Im looking for replacements for C1681, A561, C644Y for an old Yamaha PM400...hard to find anything on them.
