Khron
Not really, no. More like, it affects the max undistorted SPL :)
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
G-Sun
Ok, then I can share my build :)
HJFP2, ssl9k, Harrison Ford Filters
My music
G-Sun
So, here is my Fet847
Featuring
- Original BM800 body and headbasket
- 3Uaudio GZT-47 transformer
- Capsule: http://www.wgtcenter.com/microphone-34mm-large-mylar-capsule-diaphragm-condenser-double-sided-m7-k47-k49-k87-mount-for-neumann-mic-diy-replacement-pro.html
Soundfiles:
https://www.dropbox.com/sh/e31qlgyopwphlar/AAAdPGuv_DK2bBDwCbxYpZFna?dl=0
Sorry for not having an LDC to compare with, and for some noise on my ssl9k ch2, and for bad performance (well, sharing anyway  :) )
Comparing with
Line Audio cm3 SDC
BIV1 ribbon mic, and
RE20 dynamic
What I hear: The Fet847 as I made it is a little strange sounding on vocal and guitar, not a favorite here.
But on djembe (and probably on more perc. it sounded very usable)
« Last Edit: October 23, 2017, 12:34:21 PM by G-Sun »
My music
Khron
Does yours take 5mins (or more) to reach "full" level too?
G-Sun
Can't seem to noticed there was anything like that.
My music
I made this PCB for my personal use only. Poctop is already selling a nice PCB for this project  ;)
The Badge is from Frank Röllen (frontpanels.de) The quality is excellent.
I just built the Poctop board. I prefer the way your board implements the transformer.
gearhunter
Hi!
I am about to finish the build of my fet847 (I hope so) and I have two questions.
I have seen that the Cinemag CM-5722 has a copper foil for grounding the lamination. Should I do something with it or leave it as it is? I have seen that in some builds they have cut it.
Regarding biasing the fet, since I do not have an oscilloscope, I have chosen to use the computer as such without having had success. I have been able to modify the value of the variable resistor to obtain 10V at the drain using a DMM but I want to adjust the value of the resistance so that it adapts more to the FET I have chosen for the circuit.
What I have done with the computer has been to generate a 1kHz tone that has left the 1L output of my Audient ID14 to connect to the ground of the PCB and to the capacitor C1 connected to the FET Gate using a TS cable. To capture the signal I have simply connected the XLR of the circuit to the input of the card, which has provided the phantom. To do the routing and analyze the signal I have used Studio One with the plugins that it has as standard. (Tone Generator + Scope)
The problem I have is that the signal delivered by the microphone is so low that I have to raise the gain of the preamp practically to the maximum to be able to see a bit of the sine wave and I am not able to do the biasing process in these conditions. At least the circuit has not burned when the phantom was turned on. Does anyone have any idea what I'm doing wrong?
Khron
Have you considered turning up the output of your interface? And/or the levels in S1?
The tone generator plugin has an output level control, but it might not default to maximum.
You can't really "burn" anything, because phantom power is supplied through a pair of 6.8k resistors inside the preamp.
gearhunter
Yes, I can only see signal  when the output level of the tone generator and the output of my interface (I have checked the ID control pannel too) is almost all the way up.
« Last Edit: January 25, 2018, 06:58:26 AM by gearhunter »
Khron
What if you try recording some actual audio with the mic?
gearhunter
Problem solved!
To be able to bias the fet with the method I described with Studio One I had to disconnect R2 and C11 from the teflon pin
hi,
I just begin in the mic building and obviously i have a question
There is no more 2N3819 (semi conductor jfet) available on Mouser. So,i ask for another parts and we tell me the NTE312 -  JFET Transistor. BUT he 's also unavailable. As a noob I can't find another parts by myself and buy one in US is kind of expansive. Have you any alternative that I can find in europe ^^ ?
Thx a lot
Max51
Hi everybody !
There's still someone ?
Does someone still get a pcb for that project to sell ?
Thanks !
Micmods
Could we get a photo of the back of the board?
Khron
It's a secret!.. ::)
Not that anyone cares, but a while ago a whipped up a much cleaner layout within the same board outline.
Can't remember whether i did a second version too, without axial electrolytics, but i know i wanted to.
That being said, once both are done and "polished up" (silkscreen etc), i'll throw'em up on Oshpark or something.
« Last Edit: March 01, 2019, 09:02:43 AM by Khron »
I care. I'd definitely build your version if you put it on Oshpark.
Khron
Duly noted ;D I still cringe when i see the dog's breakfast of a layout that the original is...  :o
I "even" managed to squeeze the whole thing onto a single layer (so that much easier to DIY).
Strick9
I am also interested in one
Khron
I made a version that will fit BM800 bodies as well.
shot
Wow this is great!
Any chance you would share printable etch file or Eagle's BRD file for a (small) bunch of us home etchers?
Luka
