mkruger
i understand the concept of the star grounding technique, but i'm curious to know what is overkill and what might make it better.
If I run a seperate ground wires from each grounding point to the star ground point will this defeat the purose? I'm working with a two channel tube preamp that would probably have about 50 ground wires if i did it this way instead of using one ground wire per circuit board.
know what i mean?
know what i mean?
