Hello guys,
Thank you for this very useful thread. I built 2 units based on the scheme showed in the first message and they sound great. I used Carnhill transormers. Both units are in the same box and are powered by the same PSU.
When i test each unit individually, i get a B+ voltage of about 190 V with about 3 V on the cathode resistor (which is 220 Ohm as stated on the diagram). However, when the two units are feed in parallel from the PSU, the B+ voltage drops to about 150 V with a cathode voltage of 2,2 V approximatively and I can not figure out why ? The low voltage supply for heaters remains quite stable in both cases.
Do you have any idea ?
Thanks.
