dacapitan
Problem with recording chain
« on: December 02, 2015, 01:26:01 PM »
When I patch my EZ1073 into my Drip La2A  all the low end disapears but when I just use the 1073 or LA2A in isolation it is fine - this it how it is setup DAW -> DAC -> EZ1073 Line In -> OUT -> LA2A IN -> OUT -> ADC -> DAW.  All using balanced cables and balanced patch bay.
I think its a balanced/unbalanced problem? but I thought they were all balanced inputs and outputs?
pvision
Re: Problem with recording chain
« Reply #1 on: December 02, 2015, 02:46:56 PM »
If the low end disappears you're going "single-legged" - in other words,  one leg of the balanced line is being lost
Nick Froome
dacapitan
« Reply #2 on: December 03, 2015, 02:10:12 PM »
Hi Nick,
Thanks for replying.
Any idea of what may be the cause of this, because they work fine in isolation just not when chained?
Nick Froome
dirtyhanfri
« Reply #3 on: December 04, 2015, 06:48:17 AM »
Maybe an impedance issue between the output of the 1073 and the La2a's input...
Working on it...
joaquins
« Reply #4 on: December 04, 2015, 07:59:00 PM »
If the low end loss is "subtle" (~100 Hz) it might be an impedance matching problem (LA input is too much load for the EZ)
If the low end loss is quite bad (~1kHz) it probably is a wiring problem. Check the interconnection between them. Are both of them balanced? Are the pins 2 and 3 properly connected between both of them? (if XLR or equivalent if not) Isn't any of them open? Shielding connection shouldn't be a problem like this so I wouldn't pay much attention at first.
JS
If I don't know how it works, I prefer don't turn it on.
kosi
« Reply #5 on: December 05, 2015, 02:34:05 PM »
check all cables !
yeah, sounds silly, but ...
also check the patch bay connections !
I had the same problem a few days ago and I  wiggled one patch cable and return of the bass.
« Last Edit: December 05, 2015, 02:37:40 PM by kosi »
