ln76d said:I didn't found "rectangle hole" anywhere in eagle.
ln76d said:Still didn't found, testpads are probably to big.
Why not use round?
You need to create the hole in the "Milling" layer, the one that permits cut-outs; IIRC it's layer 41. You may use a standard pad and add these manually or want to create the complete pad and save it as a device.dirty1_1garry said:Hi!
I need to create a pad with rectangle hole instead of pad with standard round hole for toggle switch. Any info how it's possible to make in EagleCAD?)
the holes are round in all these pads. he wants elongated holes.Gustav said:Maybe Im missing something obvious, but per the picture you uploaded, shapes like that are routed, just remember to specify it as a pre-fab routing when exporting the gerber.
Gustav
