Modules, console, tape machines, etc
cmuller0420
Kelowna, British Columbia, Canada
Auditronics 110 modules
8-preamp modules $50ea
1-preamp w/eq $80
8-Output cards w/ jensen xfmr $35
Master section and psu available
Ampex 400 mono machine - electronics doesn't pass signal.  Transport works but needs some adjustments etc.  heads are okay.  $900
Ampex 351 mono - electronics work, transport untested (motor caps for sure need replacement) heads are pretty work. $900
10-ADM preamp modules xfmr and discrete op amp $50ea
6-ADM EQ modules $50ea
NTP phase meter and stereo ppm meter
Student 963 channels (mic/line), master modules, meters,
Also have a 32ch 963 console  that is considering being chopped up if anyone wants to build a custom 16ch mixer
Studer EQ and Dynamics modules
Studer equipment would be best to discuss what you are after
Yamaha PM1000 console (or part out). $1000
Genelec 1031a monitors $1500
Open to offers
do you have 2 ADM Preamp and EQ Modules left for sale ?
I' m located in Germany.
Markus
You can find the schematics for the ADMs on the web. I had them, but lost a lot of docs last year. The DOA is 202. Very similar circuit to an API. Maybe I can find what I used to have.
I converted some of these to 500 series mic pres a while ago. I could post some pics if anyone is interested.
I had to cut down the board and cut traces to the gold teeth and use wiring to get the pinout right. Add an output transformer next to the input.
Tried to PM , but your inbox is full...  I'm interested in the ADM stuff, and possibly some of the Auditronics as well.  Have any of this left?
