Hi all,
I have this AKG D30 with a connector made of unobtanium.
Actually I am considering building a connector myself - the metalwork is the "easy" part in this.
but how to build the actual connector assembly?
It is three pin, with blade-like connectors. Size-wise it looks as if the blades from a Siemens 3o pin connector could fit, so I consider "recycling" one of those and bring them into the correct shape.
I would mount them on the microphone connector and then try to cast with some resin - but what material would be suited best? It needs to be firm, reasonably temperature proof for soldering, and it should have a firm grip on the connector blades.
What would you suggest?
(And yes, building a different connector into the microphone would be much easier most probably, but only half the fun...)
