Is it? Omeg pots are similar to many others; the "log" taper is obtained by joining two "lin"sections. Depending on the type of ink and the way it is applied, the transition between the two sections is more or less smooth.xp200061 said:I bought omge log pot.
It is a little bit strange curve right?
Can you measure it and post the results?xp200061 said:Hi
I used many pot. tocos, alps, alpha, bourns and etc,, for SSL, neve urei,,,
but I think Omeg log pot is a little bit strange curve.
log curve is almost 15A. but Omeg is likes 10A+15A. I think.
It looks like the Omeg pot has a better approach to a log curve by using a three-segment screen. IMO the TOCOS is the wrong one, with the cross-over at more than 60% of the rotation instead of 50.xp200061 said:I measured Tocos log and Omeg log pot.
Orange is Tocos log pot. Blue is Omeg log pot.
X = angle Y = Resistance.
Sorry, I misread your graphs; so the Tocos is the red one, and definitely better with 3 slopes. The Omeg is indeed weird.xp200061 said:The chart is just for compare.
I use both pot on gear and I was felt strangely with omeg pot. 0 to 50% amgle does not change mostly.
and It changed sudden from about 70% angle.
Yes. I know modify the taper. But didn't work with omeg pot.
Application is normal audio gear. Forexample 1178 or 1176 input, EQP band width,,,
Thanks for the info. They are virtually unknown here. Nice range.JohnRoberts said:
abbey road d enfer said:Sorry, I misread your graphs; so the Tocos is the red one, and definitely better with 3 slopes. The Omeg is indeed weird.
You may contact them; I have found them to be receptive to comments.
BTW, who are Tocos?
You're lucky... I used to have to deal with aggressive purchasing clerks chasing a penny cheaper part to win a cost saving. Even a penny matters when buying a million pots a year.abbey road d enfer said:Thanks for the info. They are virtually unknown here. Nice range.JohnRoberts said:
Pot manufacturers should provide taper spec sheets.xp200061 said:Hi
I understood about 2 slopes or 3 slopes cost. 2 slopes is cheap right?
And 20dB is the more common value? It is difficult to use for me... :-\
