zamproject
- Joined
- May 11, 2010
- Messages
- 1,511
Hi all
I decide to start this tread as my 89MotioN system is at crucial steep.
It's an automated fader system, full analogue PID motor driver allowing compatibilities and noiseless operation with passive audio fader and low level audio path.
The v1 boards (17pcb for 8 fader pack + SMPS, core and line tx/rx) work fine, actually interfaced with midibox hardware and MB_NG software using MCU protocol. It still need some correction and crash test
I'm on this since two years, I believe I take one of the best route possible, and the result is good, I can leave and work with the actual implementation/design. But the next steep a "release", to be short, will implies little more work.
The main point here is to take temperature and see potential interest around for a system like this:
here is non exhaustive list of actual spec
-8 analogue PID and analogue touch detection for 8 motor fader (TKD and ALPS tested)
-64 digital in and out for led and button as follow:
8 din interfaced to touch detection
8 dout used do drive optocoupler, to allow analogue side remote without digital noise... in my case FET mute
8 dout used to bypass motor
6 din/out (per fader) illuminated button for remote, solo/mute/auto-read/auto-write/user/select
8 spare din (button)
-8 AD and DA converter to read (from servo track) and send (to motor driver) automation data, 10bit<=>1024<=>0.1mm steps for 100mm fader
-Dynamic spec give around 100ms full scale travel.
-Static spec give 0.01dB repositioning accuracy, by comparing (at step position) 2 audio re-recording pass, phase inverted of the same automation read. Impressive but it's done in a short time range, same temperature etc...
-core STM32F4
-Vero SMPS (you need a high quality supply, with sens)
-Line TX/RX for computer/psu 19" rack up to 10m
Estimated cost is in the 3k (+/-1k) range, depending of fader choices and mechanical integration, for 8 fader pack.
It's not at all a cheap DIY project, nor an easy on, it involves digital and analogue electronic and some programming knowledge.
But it could be the first OEM DIY moving fader system so...
Let me ear what you guys around think about this.
Best
Zam
edit 30/01/16
for HUI protocol and PT user,
group member Zander from Belgium start a discussion about it, have a look.
http://groupdiy.com/index.php?topic=61673.0
-core STM32F4
Best
Zam
edit 30/01/16
