opacheco
Lightpipe ADAT Audio input Question
« on: April 23, 2017, 03:27:36 PM »
Well I am not an expert in this theme and this could look like a stupid question:
I am in the acoustic measurement process and I have a old Presonus Digimax ADAT Audio OUT by Lightpipe only at all and I would like to get an advise in order to know if Do exist a way to connect this Interface to my Mabook Pro Retina??....do exist a especial adapter (or device) for that ??....I need to be able to do some acoustics measurements around the room under test and this can be low cost now for me if I can use this interface.
Any comment will be appreciate so much!
Opacheco.
I love the Vaccum Tubes Sound!!!
cyrano
Re: Lightpipe ADAT Audio input Question
« Reply #1 on: April 23, 2017, 05:16:52 PM »
Sorry, you're out of luck.
The Presonus only has ADAT out and the MB Pro only spdif in. One is 8 channels and the other is only 2.
The only interconnect is an audio interface with ADAT io.
Why is it people love to believe and hate to know?
opacheco
« Reply #2 on: April 25, 2017, 11:35:37 PM »
Cyrano,
Thanks for your comments!....but what audio interface with ADAT io do you know for that work??
Thanks again!
Opacheco.
abbey road d enfer
« Reply #3 on: April 26, 2017, 01:30:59 AM »
Cyrano,
Thanks again!
Opacheco.
Why do you want ADAT? ADAT is convenient when you need 8 channels and fiber connection. Any decent USB interface will be adequate for acoustic measurements.
Whoops
« Reply #4 on: May 23, 2017, 05:36:32 PM »
you need a "Soundcard or Audio Interface"
what you have is "8 Microphone Preamps with 8 Analog to Digital converters"
Get an USB Sound card, 2 Ins Line or Mic and 2 Line outputs
Price starts at 33€ with only 1 Mic Pre, 16bits 48khz
https://www.thomann.de/gb/behringer_u_phoria_um2.htm
Better is 2 Mic Pres and 24Bits 192khz, price starts at 66€
https://www.thomann.de/gb/behringer_u_phoria_umc202hd.htm
theres loads of options in the market in terms of Audio Interfaces/USB Soundcards
As for microphones, well I tested the measurements of this microphone against Bruel and Kjaer, Earthworks and Beyer Dynamic measurement microphones and the results were exactly the same:
https://www.thomann.de/gb/behringer_ecm_8000.htm?ref=search_rslt_behringer+measurment+mic_123218_17
opacheco
« Reply #5 on: May 30, 2017, 11:12:15 AM »
Whoops link thanks for help and advises!
Opacheco.
