[quote author="PRR"]> I'm having a problem with the effects send/return.
"a problem"?
Anyway: there's nothing to that. Pickup goes to send, normalized to return, and then to everything else. Open it up and see. Broken wires, dirty jacks, not much to go wrong. Do notice that the signal level is "guitar pickup", NOT "line level". Your guitar effects will work, high-level toys will get less signal than they expect. And depending on model, the pickup signal may not like to be loaded.[/quote]
Thanks for the tips PRR.. I'm suspecting a bad solder joint or something like that, as you mentioned.. It's been in storage for a few years, so i'm sure i'm gonna have to do a bit more servicing.. I know it certainly needs a few tines. I didnt investigate the problem at the time, but the symptom was: Plug in an effects pedal (in this case ring modulator) and nothing comes out of the speakers.. The model I have is a very early 'Rhodes'. It still has the wooden hammers as opposed to the plastic ones as most other 'Rhodes' have, it's stamped 1974 if i remember correct.. Any tips on tuning it PRR? I've tried in the past and attempted 'stetch' tuning but I'm sure I screwed it up. Wound up bringing it to a local tech. I'd like to tune it myself this time and get all the pickups adjusted properly. The action is thankfully nice (at least the last time I played it, it was..) :guinness: :guinness: :guinness:
-Jay
