CJ said:
no i do not get hi on pot anymore,
DIY hi potter would be a cool project, can you draw me a quick circuit?
Here is a DIY rig I whipped up to make (almost) 500V to test the insulation resistance of my outlet tester before I darkened UL's door. They require 100M @ 500V.
The rig is simple, 4 identical transformers with all the secondaries connected in parallel. 120 VAC is fed into the first primary, and the other three primaries are stacked in series, making an auto-former with roughly 4x mains voltage (confirmed)
To measure my 100M input resistor I used a VOM in current mode, and calculated backwards to impute the resistance. Using this Rube Goldberg test rig, I estimated my 100M input resistor was only delivering about 50M of insulation.
I did not have much faith in my test rig, but luckily a friend had a megger laying around that he wasn't using and lent it to me.
Surprisingly the fancy fluke tester confirmed my crude measured short fall in insulation resistance.
Once I trusted the measurement data I dug deeper to discover why my 100M resistors were not behaving and got a little quick education about SMD resistor voltage.
Small SMD resistors are only rated for 50-100V. At 500V stuff happens. To get 600V rated SMD resistors involves going up to 2012 or larger smd packages.
PS: I am not comfortable with 500V diy, but if careful you should be OK. I put a small fuse between the first secondary and the other three, but it could still easily kill me long before that fuse blew.
