matta
Hey Guys,
I am now adding the Lorlin's to my Greens and will then be wiring up
the audio connections and hopefully they work!
I have the Gain switch layout from Peter and he has named the 12 poles 'a' through 'l', I assume these are 1 to 12
as indicated on the Lorlin I have below.
I have seen Kev's switch (below) and it is a great help, but I just want to check with those of you
who have built them before I start soldering.
Below is the switch I have, I have marked and the values of the resistors
below the poles, is my thinking correct.
Then on Kev's it looks like the 1R5 goes to the center pole (A). Where do you then attached the
2 wires that go to the 2 pole on the board.
Thanks in advance.
Matt
Thanks in advance.
Matt
