Re: Creating of 2254 style compressor {CREATED} samples added!
« Reply #100 on: December 09, 2016, 02:32:50 PM »
any info about if it is more or less expensive than this :
http://www.audiomaintenance.com/acatalog/aml-17-029_extended_info.html
that include limiter as well....
Great Lee-M's review as answer on your question.
My opinion:
DB54 will cost less. How much exact? Depends on your parts. You can follow link with build info, spend a little bit of time and calcuclate exact yours cost.  DB54 contain only compressor, so minus one additional trx that used in limiter sidechain. I used lorlin switches instead expansive (but better of course) Grayhill . EZ2254 can used only Carnhill transformers, DB54 can use any suitable.
kosi
« Reply #101 on: December 13, 2016, 05:29:49 PM »
PCBs arrived in Berlin,
they look and feel fantastic.
plus very well packed.
Really looking forward to building these.
thanks a lot !!!
MrBlomski
« Reply #102 on: December 14, 2016, 12:44:37 AM »
My opinion:
Is it possible to use Grayhill switches instead of lorins? And if so, what is the production number?
M
RuudNL
« Reply #103 on: December 14, 2016, 02:07:55 AM »
Is there a schematic available, so we can see what we are talking about?
(I scanned all previous posts, but didn't find it.)
There is a solution for every problem!
http://www.vansteenisaudio.nl
3nity
« Reply #104 on: December 14, 2016, 08:57:14 AM »
Great project and awesome sounding.
I dont think grayhill makes something like lorlins!
Life is a path, death the destination.
« Reply #105 on: December 14, 2016, 08:58:41 AM »
M
No, it's impossible to use Grayhils switches on DB54 boards as pcb designed with Lorlin switches seat place. For my opinion Lorlin are GOOD switches, absolutely not bad. Never had any troubles with them, they are in my first choice list. You can find them in Thermionic mastering equipment for example.
TwentyTrees
« Reply #106 on: December 17, 2016, 08:17:22 AM »
Boards arrived today! And I have to say, they look fantastic. Really nice quality. Thanks Igor! Looking forward to getting stuck into this one in the new year...  8)
Spencerleehorton
« Reply #107 on: December 17, 2016, 08:55:51 AM »
yes, I'm applying  my DIY approach on this one, PCBs have been made, need drilling, transformers will be wound and psu built.
nice project for next year.
website: www.mohawkstudios.co.uk
email: [email protected]
If it hisses its probably the wrong impedance!!!
Or a snake!!!
« Reply #108 on: February 09, 2017, 02:02:11 PM »
First DB54 picture  :)
TwentyTrees
« Reply #109 on: February 13, 2017, 07:59:30 AM »
Hi Igor,
I'm probably missing something really obvious, but I'm not clear on the values of the 'attack time' resistors (R23-28 on PCB1). The BOM lists them as "?? See manual" - which manual do you mean? I can't find anything in your Google Drive folder setting that out, and haven't been able to find anything either elsewhere on GDIY or on Google. What values should we be using? Like I say, I feel I must be missing something obvious here...
Linked to that - do you have a schematic for the DB54?
Cheers!
Andy
« Last Edit: February 13, 2017, 08:16:07 AM by TwentyTrees »
kosi
« Reply #110 on: February 13, 2017, 08:14:38 AM »
Also missing in the bom is the part number for the connectors, that hold the BA cards
RolfGi
« Reply #111 on: February 17, 2017, 02:53:33 PM »
Hi Igor
The PCB`s are soldert (they are very nice) & the PSU is working..... :D
Now i need some info`s about how to hook up the transformers and later on how to calibrate the compressor......
Shematic would be nice ;)
Thank you very much
cheers
rolf
« Reply #112 on: February 23, 2017, 05:13:29 PM »
first of my two DB54 finished ;-)
kosi
« Reply #113 on: February 23, 2017, 05:37:11 PM »
Looks very nice, congrats !
Can you tell me the part number of the BA card connectors ?
thanks,
Andreas
« Reply #114 on: February 23, 2017, 06:05:28 PM »
Hi Andreas, hab die in ebay (aus Hong Kong ) geschossen. ca. 2 EUR das Stück....
kosi
« Reply #116 on: February 24, 2017, 06:08:29 AM »
thanks a lot !
tommypiper
« Reply #117 on: February 24, 2017, 09:56:31 PM »
No schematic for this project?  Or is it an exact clone?  ? ???
Imagine a wet, slightly chilled from its gas release and decompression, with water droplets condensing, sucking surface tension, slowly sliding down the side, capped by a healthy virgin froth on top..
TwentyTrees
« Reply #118 on: February 25, 2017, 01:50:13 PM »
Great build, cptpfeffer! Love the autograph.  8) Thanks for the BA card link as well, have snaffled a set for myself too.
« Reply #119 on: March 06, 2017, 02:37:06 PM »
Hi all!
I'm in a process of gathering all the part for this project an I need some help.
1) Is this power trafo good? http://www.banzaimusic.com/Talema-TRT30215.html
2) Which BC184C transistors need to be matched with each other, it's hidden in the BOM?
3) I'm also curious about those ??? resistors (R23 - R28) used for attack?
Last post September 13, 2012, 11:13:28 AM
by Igor
Last post May 03, 2020, 02:05:09 PM
by Greebok
Last post March 02, 2020, 09:09:16 AM
by Zergonion
Last post April 07, 2020, 03:47:25 PM
by [email protected]
