slipperyflax
Active member
- Joined
- Oct 2, 2016
- Messages
- 25
Twentytrees have you summed up what your total project cost was? Or maybe an estimate
slipperyflax said:Twentytrees have you summed up what your total project cost was? Or maybe an estimate
TwentyTrees said:Hey Slippery,
I’ve not got exact figures to hand as I spread the orders over a long period, but I’d estimate maybe £4-500 per channel for a stereo build - of which a large part was transformers (6 Carnhills for two channels) and the panel, which was powder coated and engraved by Frank.
Not cheap, but probably my favourite build so far. Wish I could get the meters to track again reduction accurately over the whole range, but no matter, it forces me to use my ears!
(The meters on my unit track g/r accurately to about 4dB but then the scale goes way out - no matter how I set them up I couldn’t get them accurate across the whole meter range).
Andy
dirty1_1garry said:Hi folks!
Did I miss something?)
If you need my help - feel free to contact me directly.
frederickalonso said:Hi Garry,
I just want to ask if you have an idea what can be the problem in volume drop when the compressor is switched in.
Bypass vs comp in = 40% difference in volume at this moment.
No hum or hiss, all the rest is working fine and I love the units.
Maybe transformer related? I used all Carnhill transformers on all 3 stages.
I could PM you but on this forum it could help other people here as well.
dirty1_1garry said:Check transformer wiring first. Then I can recommend to measure signal level during signal chain, as originally you should not get a such level drop.
frederickalonso said:I followed the numbers from the Wiring Guide correctly. The only thing that I can try is switch the output transformer so the used input side becomes the output and vice versa. But don't think this will make much difference and is a good idea.
I took a good look on the Carnhill transfo pdf and from their numbers vs yours it's just the same.
Would love to know some measure levels on the BA card pins for example from a working unit so I can dig deeper.
Strange enough I have it on both units > same voltages and levels on both.
dirty1_1garry said:Yes, if tranformers wiring is Ok, next step would be check signal level during sound path.
Send 1Vac to the input trx and measure level at points:
1) after input trx (pin7) = 0,1Vac
2) before (pin2 = 0,1Vac) and after(pin7 = 0,1Vac) of interstage trx
3) output pot pin3 = 0,1Vac
4) BA283 card pin F = 0,1Vac
5) output trx secondary = 0,1Vac
frederickalonso said:I also have put 1Vac on the interstage to test a little bit more...
on pin 2 and after pin 7 of interstage trx and then I have these results:
1) after input trx (pin7) = 0,5Vac
2) before (pin2 = 1Vac where I feed 1V) and after(pin7 = 1Vac) of interstage trx
3) output pot pin3 = 1Vac
4) BA283 card pin F = 1Vac
5) output trx secondary = 1Vac
frederickalonso said:Hmmm, this was interesting.
So I disconnected the ground wire as it normally should be like but this made a huge difference on the
47R voltage which should be 2.3VDC.
I removed the ground on pin 3 and 4 at the interstage transformer and adjusted (calibrated) the 47R again.
This fixed my issue.
So before the modification I had 2.3VDC on R7 (47R) and after the ground removal I had something like 5VDC that needed a calibration again to 2.3VDC.
Why this fixed the issue, I cannot get it. :
But It's working fine now! So happy! 1/3 more gain then input volume now, and a nice low end.
Thanks Igor!
