Help repairing Groove Tubes GT-60 tube microphone
beatnik
Italy
I've had this Groove Tubes GT60 tube microphone sitting on the pile of projects for a long time and tried again repairing it today
It went pop suddently, found some blown capacitors, replaced them didn't bring the mic back to life. I also changed the tube, a subminiature type
The power supply works fine but the microphone only outputs noise, kind of white noise with low end rumble and lots of pops and crackles. The capsule actually picks up some sound, albeit very low level, doesn't have the sensitivity you would expect from this kind of microphone
I don't really know what else to check and to further complicate the process there are no schematics available for this model. I would really like to know if someone can help me fixing it before chucking it completely
Thanks in advance
If the tube is a 5840 mini then the circuit may be very close or the same as their AM62 (originally offered as GT 6TM) scheme?
Forget this question , I did some searches, it uses a different tube
Is the power supply PSM1 ?
If so see last post on this thread for a link to its schematic    http://groupdiy.com/index.php?topic=45261.0
yeah i did find the schematic for the power supply . the voltages seems fine, i got about 125V for the B+ and 6.2V for the heaters
i exchanged some email with aspen pittman (groove tubes former owner) and he couldn't locate a schematic for the microphone
without the schematic it's kinda hard for me but maybe you can point me to some standard procedure ? it's my first time working on a tube microphone so I'm not an expert at all
