Vac11
Syt5 body + accessories
New, unused brass Syt 5 body kit for U87 or U67 clone.
Kit includes:
1x syt 5 body with black printing (-10db, HPF, polarity), brass, high quality, capsule holder incl.
1x vintage look shockmount
1x wood case with sateen inside (btw. nice looking case)
2x on off switch
1x on off on switch
3x 6mm standoff for switch pcb mounting
3x M2 screews compatiable with 6mm standoffs
1x xlr 3pin inlet
Price is 175EUR + shipping costs.
For shipping cost reasons only for EU buyers!!!!
Im open to trade this body for Jensen transformers. I need JT-16-B and JT-11-BMQ and OLI-3 RL output isolator. I can offer discount for the one who can help me buy and resend those transformers.
Contact me on: mildavaca /AT/ seznam /DOT/ cz Pleas beware, it is possible that my answer can fall to your spam folder....
Neumann U87 clone pcbs
For sale few vintage Neumann U87 clone circuit boards. I designed boards myself and built 4x U87 microphones. They fit in chinese SYT-5 bodies... Working great. Same as original (schematic ver. 16). Possibility of using bigger output caps. Point to point Hi-Z section on teflon pins. For this project you need vintage K87 capsule (isolate backplates, four wires from capsule...)
BOM and schematic included.
Price is 20 Euro per set (1x main board, 1x switches board, 1x "power supply" board).
Stuffed boards and final result looks like this:
More photos:
https://vacek.rajce.idnes.cz/U87/
Neumann M49 clone point to point boards
Boards for M49 point to point clone (FR-4 material - same as standard PCB). I designed transformer board for Mobys bv11 transformer. Circuit board for Oliver Archuts M49 circuit version. Tube rubber holder is for 6s6b-v tube. Boards are Banzai M49 body compatible. You need grommets, grommet tool and double pins for DIY the double pin eyelets.... You can find instructions for completion here: https://groupdiy.com/index.php?topic=69888.msg891466#msg891466
For people who bought those boards from me Moby  will give 10% discount from regular price of his beautiful BV11 transformers!!!!
Price is 25 Euro per set.
Here is final result:
More photos (incl. wiring diagram, schematic, ....):
https://vacek.rajce.idnes.cz/M49/
Contact me on: mildavaca /AT/ seznam /DOT/ cz Pleas beware!! It is possible that my answer can fall to your spam folder....
SSL4000EQ boards
Last 6 boards I have found in my stock. EQ circuit is exact copy of legendary SSL 82E02 EQ. So called "brown knob version"... There is also added balanced input and output circuit. I have BOM, schematic and other building documents.... Building thread and more info here: https://groupdiy.com/index.php?topic=45484.0
Price is 25Euro per 1 pcb. Sold out!
« Last Edit: January 03, 2020, 04:59:54 AM by Vac11 »
bluezplaya
Re: FS/FT: SSL4000E equalizer PCB´s
« Reply #1 on: May 25, 2016, 11:19:33 AM »
I want two of the green 4000E pcbs. I'm in the US.
Alabama is the only state in the country where the tooth fairy had to file for unemployment.
Vac11
« Reply #2 on: May 25, 2016, 01:08:55 PM »
Pm'd.
Vac11
« Reply #3 on: May 26, 2016, 09:19:35 AM »
1 green PCBs and 1 small filter pcb sold. Thanks Eric.
Vac11
« Reply #4 on: May 27, 2016, 12:44:45 AM »
All green EQ PCBs sold.
Vac11
« Reply #5 on: June 20, 2016, 04:35:24 AM »
Another small batch of green EQ pcbs.
Vac11
« Reply #6 on: June 26, 2016, 04:24:18 AM »
up
Vac11
« Reply #7 on: July 04, 2016, 12:58:10 PM »
2 pcs green PCBs sold, 8 pcs left...Thanks.
Vac11
« Reply #8 on: July 08, 2016, 05:49:27 AM »
Up
Vac11
« Reply #9 on: July 14, 2016, 02:49:00 AM »
8 green pcb sold... Thanks.
Lagrange
« Reply #10 on: July 19, 2016, 10:03:29 AM »
Sent email. :)
Vac11
« Reply #11 on: August 20, 2016, 02:51:06 PM »
New batch...See first post.
Vac11
« Reply #12 on: August 24, 2016, 10:22:27 AM »
2 boards sold. Thanks.
peterc
« Reply #13 on: August 24, 2016, 10:53:04 AM »
Should this not be in the White Market?
Just saying.....
If opportunity doesn't knock, build a door.
Vac11
« Reply #14 on: August 24, 2016, 10:57:46 AM »
Bump
« Last Edit: March 19, 2019, 04:19:04 AM by Vac11 »
Vac11
« Reply #15 on: August 29, 2016, 02:25:14 PM »
Bump
Vac11
Re: FS/FT: SSL4000E equalizer PCB´s, inductors, ACDC pcbs
« Reply #16 on: September 02, 2016, 04:55:06 PM »
Some items added...
Vac11
« Reply #17 on: September 09, 2016, 11:27:53 AM »
Bump
Vac11
« Reply #18 on: September 17, 2016, 02:33:11 PM »
bump
Vac11
« Reply #19 on: October 03, 2016, 01:30:54 AM »
up
Last post August 07, 2019, 03:20:39 PM
by Rlucas41
Last post March 14, 2019, 07:41:03 PM
by Wordsushi
Last post May 16, 2018, 03:42:29 AM
by Zebra_PD
Last post March 19, 2019, 12:36:19 AM
by Blue Jinn
