kpearsall
Re: Beesneez M49 Feeler, Now Ready to ship!!!
« Reply #160 on: August 05, 2018, 06:07:28 AM »
Thanks Gus I hadn’t seen that! I can certainly say that his issue was not my own however. I checked all that over and over, and what’s more, I never had any issues at all with hum or buzz. Clean mic just way too quiet. Unplugging the mic from the pre I realized that all the noise I was hearing was coming from the preamp I had cranked. Not even hearing the noise from the mic itself. This was all after troubles with a bad batch of tubes, so I was pretty much at wits end. I take my time and give all my attention I’ve never had a build just totally not work right from the start. I suppose I was due...
« Reply #161 on: August 05, 2018, 04:24:14 PM »
Have you read this?
https://www.tapatalk.com/groups/prorecordingworkshop/what-would-cause-this-t19410595-s10.html
Shouldn't be this complicated to provide clear wiring diagrams for transformers...
Or just make wires the same colour as originals: clients can look at vintage mic schematics, follow the colours, and never have a problem.
Neumann always marks them: sw=black, rt=red, bl=blue, gn=green, ge=yellow, bn=brown
stelin
« Reply #162 on: August 07, 2018, 04:23:47 PM »
Banzai: The AMI T49 is a PCB mounted transformer. There are no coloured wires.
The terminals are labelled A, B, C and D.  A and B are (should be) the the primary, C and D the secondary.
The transformer board in poctops PCB kit has the same labels, so it's very hard to get it wrong. If the labels on the trafo is right.
« Reply #163 on: August 08, 2018, 02:03:00 AM »
The guy in that thread had a BV11R
wmarden
Re: Beesneez M49 Feeler, Now Ready to ship!!! New
« Reply #164 on: January 10, 2019, 04:31:53 PM »
Correction... Hey  Ben, I've been out of pocket for awhile but am wondering if any of these kits bodies are still available..?
« Last Edit: January 10, 2019, 08:07:55 PM by wmarden »
